Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riduing tractor turns over but won't
Craftsman riding tractor turns over but won't start. Have checked sparkplugs and have spark. Have installed new battery
craftsman 20.5 hp lawn tractor model 917.270951
    Scholar:
  • 110 Answers
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
Posted on May 09, 2010
  • 3 Answers
Had the same problem. Removed carb, carefully, noting where everything goes and taking some pics, completely disassembled and thoroughly cleaned. Reassembled and worked like a champ. Reason for this? Gas goes bad and gunks up the carb. Good luck
Posted on May 26, 2010
  • 44 Answers
Check kill switches, under seat, clutch & blade engage lever, and make sure its in park.
Posted on Jun 01, 2010
  • 66 Answers
Like the others have mentioned...that leaves a fuel issue. Try pouring a little gas down the carb (take air filter out first) to see if it will pick it up. Depending on how old the gas is in the tank...you may have to drain the tank and clean the carburetor. I recommend using a form of stabilizer in the gas when storing the machine during the off-season. Do no use dry-gas in any of these engines as it will do more harm than good. www.nnyparts.com
Craftsman DGS 6500 with Kohler engine won't do anything when I try to turn it over.
IS THERE IS ENOUGH OIL IN THE OILCARTER ? IS THERE A CLOGGED AIRFILTER ? OR DIRT IN THE FUEL FILTER LINE CARBURETOR FLOATCHAMBER NOZZLE ?
IF THE SPARKPLUG REMOVED AND FITTED IN THE PLUGCAP AND IF YOU START AND PULL THE TRIGGER HOLDING THE SPARKPLUG AGAINST A METAL PART .LOOK ALSO FOR A NICE BETWEEN WHITE- AND CHOIRS BLUE COLORED SPARK. IF ITS RED REPLACE THE SPARKPLUG IF ITS STILL RED OR DOES NOT SPARK REPLACE THE IGNITION COIL.
Feb 17, 2016 | Craftsman Garden
Replaced sparkplug, solenoid, and battery - riding mower still won't start
check for spark if none remove the harness from the engine and crank it if you then get spark check the safety switches
Apr 22, 2012 | Garden
Not getting fire to new sparkplug
first does it turn over at all. if then check to see if the blades are turned off, out of reverse seat interlock ect.
Jul 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Run out of things to check
coil{solid sate ingnition) see if u hav spark ground plug,low light {shade} to see spark,AWAY FROM BUILDING and GAS!! hav fire extinguisher handy..remove all ignitable fuilds,well ventilated area..if spark,check "kill" switches on throttle,clutch pedal and seat.
Aug 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cranks but won't start after we replaced one broken belt below deck
try different spark plugs. sometimes because they are new doesn't mean they are good. check the bottom of the old plugs for raw fuel.
May 24, 2009 | Craftsman Garden
No spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
Apr 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
759 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
