Question about Dishwashers
GE Monogram ZBD0710 Dishwasher
The handle has become loose but I don't see any allen screws to tighten. The owners manual and installation guide don't offer any help.
  • 3 more comments
  • Anonymous Nov 01, 2008
    The post holding the handle to the door is tight. The handle is loose from the posts. How do you get the end caps off to access what I suspect are set screws?
  • Anonymous Nov 16, 2008
    Same problem.
  • Anonymous Nov 22, 2008
    same problem. can't figure out how to tighten the handle to the post.
  • mitchcbs Feb 26, 2009
    My problem is that while the handle is properly tightened to the short posts (called standoffs?), the posts themselves are coming loose from the dishwasher door. Do I need to remove the entire inside panel of the door to get at these screws, or do I just remove or loosen the two large phillips-screws nearest the latch?
    Thanks!
    [email protected]
  • westergrentk Apr 20, 2009
    There is no way to remove the inside panel by just removing two phillips head screws. I actually had to remove all and the entire guts were falling out all over. I had to put inside panel back on and am still without handle or any way to put handle back on. I hate G.E. what a mess! Oh Yeah, I have the ZBD6880 Model.
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.  Here's what to do.  You must fully remove the handle from the appliance.  Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.  There is no need to remove the end caps.
Posted on Nov 26, 2008
The solution from davidburroug is the one. The local appliance repair store told me I would have to buy a new handle! Thank goodness this solution appeared before I went to the expense.
Posted on Dec 05, 2008
Agree, this procedure works to tighten the main post to the door. What about the handle to the post? Again no allen screws present, but it apprears each end of the handle has a cap on it. How do you remove those caps to [hopefully] gain access to the bolt to tighten.
Posted on Oct 05, 2008
    New Friend:
Im am going to try Solution 4, I was wondering about the two screws near the door latch. You neeed to get inside the front cover to tighten the standoffs down. What a crapy design..... it sounds like everyone has the same issue I do. GE sould change this design, and have a recall. Pisses me off............
Posted on Dec 17, 2009
You need to remove the front panel to tighten the handle mounting bolts from the inside. Open the dishwasher door and remove the phillips head screws from the inside of the front panel. The two phillips nearest the door latch only need to be loosened, not completely removed.
Posted on May 05, 2008
6ya staff
SOURCE:
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
Handlebars won't stay upright
The part that holds the handle bars on is called the Head-set this should have adjustment screw/screws they may have a small plastic cover over them to prevent rust. They are usually require an Allen wrench to tighten them. If they become loose again then get some locktight and use this on the handle bars and the threads of the bolts before you tighten them up.
Oct 31, 2013 | Specialized Crossroads
Please tell me how to tighten the off/on handle. It is loose and I can't figure out how to take it off or tighten it. This unit was installed about 3 1/2 years ago. Thank you very much. George
There is an Allen "screw" which is threaded in from the underside of the handle.
Simply tightening this screw 'should' tighten things up.
If that doesn't work, perhaps the Allen screw needs to be replaced.
If you have the Allen wrench to fit, you don't even have to turn off the water supply, just turn the handle up and let the water flow for the time it takes to snug it up.
Aug 22, 2010 | Moen T2529 Monticello Single Handle...
The handle on the bottom freezer drawer is loose and i caqnnot tighten it by using an allen wrench in the 2 bottom holes - - is there a trick to this???
Sometimes the studs that the handle mounts to become loose themselves. If you remove the handle entirely and look at the studs, they will have either a phillips head or they will be hex-headed so you can tighten them. Carefully snug the studs down (do not over-tighten) and re-install the handle. This should solve your problem.
Let me know if you need more help
good luck
Aug 11, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Nov 27, 2008 | LG Refrigerators
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Dishwashers Logo
2,087 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
