Question about Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905
How to remove blade pulley on a kubota RCK40LT mower deck
To remove the two smaller single blade pulleys you will need at least a 5 inch bearing puller (the kind with three legs. There are two sets of bearings in both assemblies, one on the top of the spindle shaft and the second at the top. If you plan on removing the double pulley in the center that takes the power from the engine and transfers to the blades you will need at least a 6 inch bearing pulley. My recommendation is replace all the bearings, cheap insurance in my opinion. Keep notes of what, where, how each item is removed so it goes back in the right place.
Posted on May 25, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Grinding noise in mowing deck when engaged
the bearings in one of the blade houseing r going out
Jul 01, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine stalls
could be a stuck pulley or bearing, or debris in the cutting deck. make sure the blades turn freely with mower off and blades dissengaged. If they dont, remove the deck and check all of the pulleys for freeness.
Jun 02, 2014 | Craftsman Garden
Main spindle needs replacement how to
Typical Kubota mower spindles are mounted with 4 bolts. Some have 4 more on a larger support plate. First the belt pulley must be removed, possibly with the help of a jaw-type puller. Then remove the 4 bolts around the perimeter of the spindle. Using a soft mallet or wood block, drive the spindle assembly down through the deck, making sure there is room underneath for it to fall. Kubota sells replacements as complete assemblies which saves a lot of time vs. rebuilding the spindle.
Oct 05, 2013 | Kubota Garden
Changing Blades
With most small lawn tractors I've dealt with, you want to unhook the deck-blade drive belt, some have one large belt that turns the blades as well as the rear wheels, others have more than one belt.. usually you will find four brackets that suspend the entire mower deck below the lawn tractor. To locate these brackets raise the mower deck so that its not resting on the ground, then push the mower deck side to side and notice where the attaching arms are moving under mower but above the deck, once you find the four brackets, lower the deck 2 its lowest point. remove the connecting pins noting the exact hole each pin came out of, if you have not removed the belt bye now do so at this time. you may find a stubborn piece of metal preventing the belt from coming off near the larger pulley Don't bend it out of the way just remove or loosen its nut,its there 4 a reason. so now, 1 the belts off the pulley. 2. the pins or bolts have been removed from the suspending arms and the hole positions have been noted. remove any other actuating rods or levers remaining so that the mower deck can slide out from under the mower. you may have to put the front wheels on a 4x4 blocks or similar to accomplish this. once you've got the deck out carefully turn it upside down, use blocks to keep from mashing pulleys, etc. you will probably see two or three blades, remove hex head bolt w/ washer holding blade to spindle, be sure to note cutting side of blade and direction of travel. If you don't see bolts in the center of blade look for my other solution for changing blades and blade bearings.
Jul 16, 2013 | Garden
When I put the power take-off lever to the on position, the mower deck belt smokes and it appears that the right hand blade wouldn,t move
You need to remove the belt driving the blades and check to see if the bearings in the blade pulleys are not frozen which I suspect is your problem. If you find a pulley is frozen then remove the mower deck from the mower so it will be easier to access and remove the pulleys.
May 14, 2011 | Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905 Logo
756 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
