Question about GE Refrigerators
GE Model PSF26NGPVWW There is barely a trickle of water when we try to fill a glass from the door dispenser. We have checked the following: 1. Changed the filter 2. Confirmed that there is a strong flow into the refrigerator 3. Checked the connection below the freezer door
  • cdavey1 May 09, 2010
    I have checked the flow into the refrigerartor, it is strong
    I have changed the filter, its still barely a trickle
    If its the solenoid, what is the fix?
    What is the fix if its the solenoid or limed up?
    President:
  • 2,468 Answers
Either the water filter is plugged,the solenoid valve that opens to let water flow isn't opening fully or the water supply line from the house to the refrige and the line up to the water outlet is limed up from the reservoir tank in the lower unit
Posted on May 09, 2010
  • danny Hendrickson May 09, 2010
    you need to check the voltage to the solenoids and see if they open up when you want to draw water from the unit,if its been there a long time then maybe replace the lines, open these and see how the water flow pressure is up to the units water filter and replace lines/filter accordingally up to the dispenser
  • danny Hendrickson May 10, 2010
    still first check the water flow out of the filter canister,then go for the plugged line
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    Brand new GE Profile GFSF6KKYCBB French Door with external ice and water dispenser. After filling a glass of water, pull the glass out and water turns completely off as expected. Two seconds later, the...
    Sorry to read about your problem, I hope this helps you out.
    factory defective, call in warranty service
    I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
    Dec 22, 2010 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
    My new (2 months) Samsung refrigerator barely dispenses water. It just trickles out. It would take 5 mins to fill a 20 oz glass. The ice works fine (good water flow to it). The water filter is fine....
    The only thing between the inlet line and the spout?
    Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
    Mar 29, 2010 | Samsung RS2534 Side by Side Refrigerator
    No water from dispenser
    I had the problem with the water dispenser not working.i tried all kind things finally I figured out the water was freezing ing the door. I cut a piece of 1/2 styro foam out that covers right below where the ice is dispensed just a square and use double sided tape to stick it to the back side of the door and haven't had anymore problems.
    Nov 13, 2009 | GE Refrigerators
    Water dispenser is dispensing water at a trickle
    The water filter is the first item I would check. I just repaired a s/s with the same problem and it was the water filter.
    Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    One dispense spigot barely trickles
    You need to take a paper clip and clean the little holes where the water comes out on the left side (It's like a screen). Also you should pull the silver thing that adjusts to allow taller cups underneath up and down several times. You should do the latter every week. It helps get rid of some of the coffee grounds that block the aforementioned little holes.
    Oct 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
    Monogram water flow problem
    common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
    Jun 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
    GE refrigerator Leaks in back when trying to use water dispenser
    That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
    May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
    Water dispenser is extremely S L O W
    check no ice build up in bottle but the most likely cause is poor water pressure on the inlet. no cure except to improve water pressure. if there is a valve in the input water line, check it is fully open
    Apr 25, 2007 | Hotpoint HSS25GFP Side by Side...
    Refrigerators Logo
    32 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
