Question about Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: error code f20?
  • 5,081 Answers
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
Unplug the machine.
Remove the top or the back of the washer.
Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it.Pull the tube from the switch and blow through the tube until clear.
Posted on May 09, 2010
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Posted on Sep 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have an Whirlpool Duet GHW9150P Front Load
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Posted on Sep 18, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
F20 code comes on
recheck water supply. try different wash cycles see if you have same problem.
Aug 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F20 error code
Whirlpool error codes .Please check this link for tips : error codes
Jul 04, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 code
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Steam washer, F20 error. help
make sure pump is clear. open toe panel and access pump.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F20 flashing code mean on whirlpool duet washer
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
829 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
