Question about RCA D52W15 TV
No sound, No picture
TV was on :
- The power green light was on in the TV's front
- No sound
- No picture
- There were 3 clicks from the TV's back and then it stopped.
  • whisox64 Jul 02, 2008
    coaxial connection is broken off
    Master:
  • 518 Answers
The high voltage isn't firing up. Could be a number of things, but is most likely one of the following: Blown fuse, bad Voltage regulator, bad Horizonal output transistor, Bad solder joint(s) on any of the above.
Sometimes the whole power supply PC board can be replaced as one unit. There's Company called PTS Corp that rebuilds boards and will trade you for a price. They are very good at what they do. You would need the numbers off the existing board.
If you decide to look at it, please be careful. The high voltage can exceed 30,000 volts and capacitors in the set can hold a charge for days.
Hope that helps...
Geno
Posted on Mar 27, 2008
SOURCE:
Flat screen tv
Open internal fuse or power supply failure
Aug 30, 2016 | Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
RCA D52W15 TV Logo
241 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
