Question about Samsung SyncMaster 740b 17" LCD Monitor
Blank screen i have 3 samsung 740B 17" monitors its been 2 years and i have 2 down,both source buttons light up telling me power is good.ive tried different monitor with the same cpu and it works fine. i have 7 work stations at my work 4 have dell monitors running for 5 years +, and 3 are samsung,which i only have 1 left working now. only had them for 2 years. just woundering if theres anything i can try or are they garbage?
    Scholar:
  • 36 Answers
Hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
Hallo mckay14,
Seems I having the same problem, I have resoled the problem by opening the screen from the top and you’ll see on the left of the center the output cable. Now there are two things you can do:
1. Computer must be running and the LCD connected, go with your fingers inside the top opened screen and disconnect only the left side of the output. You’ll see that the screen will turn white now, put the cable back in inside now and presto it is working again.
2. Take out this cable and cut the 4 left wires, extent the cable and use as 4-way switch. Now you can use the switch in the same way, when you switch off wait for the screen to turn white and then switch it on.
You do not have to worry that you will get a shock when you put you fingers inside as that in that area only data is transfers, in other word low power on electric.
But that is not all, I can even tell you “how did this happen?”
It seems that the Samsung 740b has a problem with changing the refresh rate, was your refresh rate was @70, @72 or @75, this is not standard supported and causing this malfunction.
Now there can be a third solution without opening the screen, the Samsung 740b has a DVI input. If one of your computers has a DVI output graphic card then try that as it is using a digital signal. I have high hope for this but I do not have DVI output...
With kind Regards,
CrazyLex.
Posted on Mar 30, 2008
SOURCE:
I have a Samsung Syncmaster 710M that's about 5 years old. It had been lying around in its box for more than a year. When I tried to use it recently it shows the "Check Cable Signal" screen...
when you connect your lcd with computer and when you put on your computer after that press the source button on your lcd, then it will bring the display in front of you dear. thx
Jun 24, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
Syncmaster 740b not working
Check the DC filter caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 08, 2010 | Samsung SyncMaster 740b 17" LCD Monitor
Modrl 710N Monitor. I have just turned on this replacement monitor for the first time in about 3-months. The screen is blank with a flashing green light on the control panel. Pressing the test button tells...
When a monitor goes black and the solid green starts flashing it normally means the computer is sleep mode the screen saver blanked out the display the comp is off ect... However in this case since i assume you allready tried wiggling the mouse tapping the spacebar pressing the resume button ect... It is one of 2 things either the video card is going bad.( perhaps the computer has been on for a while and it is getting hot. With video card issues except the obvious, the case fan should be checked. there is a fan on the videocard it should checked as well the pc coul and mostlikely needs the dust blown out of it cause thats what kills fans and power supplies Hey power supply is the next possibility to th issue. No matter which part solves the problem I reccommend you do the other maybe premaintenance things I suggested. Good Luck.
Dec 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
May samsung lcd monitor have no power
Power supply unit might be bad.
Check for popped capacitor.
Mar 28, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Blank Screen, power light is steady green
have you tried adjusting for the brightness and contrast of the monitor. does any menu comes out if you press any buttons of the monitor except power of course!
Nov 16, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Screen goes blank also.
I too have an LCD Xerox - it worked fine for a while, then kept going blank and going onto standby. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I had just downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Dec 19, 2006 | Xerox XG-91D 19" LCD Monitor
Samsung SyncMaster 740b 17" LCD Monitor Logo
794 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
