Question about Lexmark X83 All-In-One InkJet Printer
Printing mechanism rattling out of control
Inside printing mechanism randomly rattling out of control. very loud!
  • Official Brand Answer
  • 3,344 Answers
That sounds like a hardware/mechanical problem in the printer. Since there are no Service Providers nor field technicians to take a look at your printer, I strongly advise you to contact Lexmark Technical Support for further assistance.
Posted on May 10, 2010
2004 gmc yukon rattling and pinging under hood and inside. Loud inside and sounds like it's fluid moving with the rattle. Not wet inside of the truck.
These engines don't rattle and especially ping unless they are hot. And the sound of fluid thru the heater core. Tells me you are low on coolant. The engine is not cheap to replace.
Oct 25, 2014 | 2004 GMC Yukon
Rattling in engine bay
check your belts and the bolts around that area, sounds like loose bolts causing something to move and rub
Aug 05, 2013 | Vehicle Parts & Accessories
Loud rattling when operating
it could be a bad fan or a bad stirrer inside the wave guide. I would suggest you get a qualified technician to come check it out.
Feb 01, 2013 | GE JVM1190 Microwave Oven
My 1984 volvo rattles loudly when accelerated
could be so many things and my suggestion would be pure guess withuot looking at it. My suggestion would have a mechanic take a look at it......the list could go on and on.....sorry and good luck.
Aug 16, 2012 | 1984 Volvo GL
Canon pixma MX 860.Its not printing anymore.when it tries it make a loud rattling noice and an error code 5c20 comes up. Cartgridges have been removed and put back.Dont know how to check on the printerhead
Hello.
To check the print head remove the cartridges. To the left of right of the cartridge holder there is a orange or grey lever. lift this and remove the print head. The rattling noise could also be the belt that moved the cartridge carriage back and forward. this belt is directly behind the carriage. This belt may have slipped from its wheels at each end of the printer. look inside it with a torch for a clear view. Before doing this please remove the power cord from the back of the printer to ensure your safety.
I hope this helps Regards GM
May 26, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Loud rattle coming from the bottom of engine. mostly heard after letting off the gas, starting and shutting off the vehicle.
Very hard to know without actually hearing the vehicle but,,,With what you describe,the cat/converter 'may' be making the sound.With the car off and engine cool,get under and give the cat/con a really give shove or hit.The insides of them do corrode and the internals make a very loud rattle.If this isn't the problem it will let you see if there is a loose exhaust mount that may also make a rattle.(The cat/con sound is like there is a very loose metal plate hitting something)Its actually the internals of the cat. that have broken loose and rattling inside it.Hope this helps
Apr 09, 2010 | 1996 Jeep Cherokee Country
Rattle from front end
hard to help with out hearing for my self, try getting different opinions from 2 other shop. may be worth it. 1 to be a transmission shop if it is a trans problem.
Aug 12, 2009 | 2005 Ford F-150
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Loud rattling noise coming from the engine
Are you losing power as well? if so it sounds like the camshaft is worn, this can be confirmed with a compression test
Jun 16, 2009 | 2005 Volkswagen Passat
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Lexmark X83 All-In-One InkJet Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
