Question about Rl Flowmaster Rl Flo Master Residential Backpack Sprayer, 3 Gal
After pumping the sprayer in just a few seconds of spraying you lose the pressure
    Problem Solver:
  • 9 Answers
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
New pump-pump works fine for 2 seconds--loses pressure--spray goes from 10-12 ft to zero...wait for pressure to build back up and works fine for 2 sec....start over....pump unusable like this
Air leak somewhere between the pump and the spray tip (s).
that will incllude the 25 gallon tank as a possible place to check for leaks!
Apr 15, 2015 | Flojet Pump D2131I5011A
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
Sprayer drips instead of spraying
Pressure test: pump it several times then open the cylinder (like you were going to pour in more solution): was there a noticeable pressure release? If not, then your problem is in the pump assembly. Examine the end (the end which goes into the tank) flapper valve. While the pump is out of the tank, pump it a few times. Do you see/hear the flapper move with inflowing air? If not, herein lies your problem. Put a few drops of oil down the assembly where the pump slides up/down. Work the pump a few times. If this does not solve the problem, try to dissamble the pump mechanism and MAYBE you will be able to replace faulty intern parts/gasket. If you DO have internal pressure in the tank, yet no spraying action: disassemble all parts coming after the pump. Hose, off/on switch/lever, spray tip. Yes, it will completely disassemble. Inspect/clean everything/blow out the spray tip or use a thin needle to clean the tip. While you have everything apart, use "silicon plumbers' grease" and generously lube all of the o-rings: this will afford a very good seal and prevent pressure loss. You can buy the plumbers' grease at the big box stores or plumbing supply places. Good luck.
Feb 12, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
I have a SOLO 461 sprayer. After months of good service, the pressure from the spray jet drops after a few seconds of spraying. If I close the trigger, then re-open it, the spray again lasts just a few...
if it is a diaphram style replace diaphram if it is a piston style replace piston how to's are easy on both just take ur time and pay attention to removal process
Jan 15, 2011 | Solo Sprayer Parts Shutoff Valve Assembly
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
I have a Generac pressure washer, model #01450-0, with a Honda 5hp motor. The motor runs fine, but the pressure hose pulsates as if the pump is intermittently making pressure, and the pressure out of the...
Take a small diameter wire and poke thru the discharge hole of the spray head to clean out.
Second time in 6 months that I had the same problem. The problem is alway in the spray head.
Jul 23, 2009 | Garden
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Rl Flowmaster Rl Flo Master Residential Backpack Sprayer, 3 Gal Logo
801 people viewed this question
Top Rl Flowmaster Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Rl Flowmaster Garden Expert? Answer questions, earn points and help others
