Question about Dometic Rooftop RV Air Conditioner
Have a 93 airstream camper with a Dometic AC unit . When I tuun the unit on either to heat or air,it brings the house voltage down to the red zone but does come on but seems to be draining the power.
  • jhaun48 May 09, 2010
    By house voltage I am referring yo 120 volts.
  • Dometic Master
  • 6,674 Answers
Does the fan seem to labor when starting up. (basically starts up but seems slow to get up to speed?) Then when fan is turning at normal speed, the power inside seems to go back to normal?
Posted on May 16, 2010
My 19 ft airstream's Penguin duo-therm a/c unit just started blowing out HOT air!!!! Why is this occurring?
If you have a heatpump model a/c unit, and it is blowing air that is hotter than the ambient temperature inside the airstream, then it is likely that your reversing valve is stuck in the open or closed position. A heatpump is basically an air conditioner that will also run in reverse (via the reversing valve) in order to heat instead of cool. The valve can get stuck for a variety of reasons, including; faulty wiring caused by rodents chewing or vibrations, insulators (dirt) between switch surfaces, or it could be a mechanical problem within the valve its self; these valves break often.
Sep 12, 2013 | Dometic Heating & Cooling
Rpod ac unit leaking
if the gasket is bad it could leak
Aug 21, 2012 | Dometic Rooftop RV Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
My Intertherm heat/ac in my camper does not heat. a/c works great, but no heat. Any ideas??
The electric heat strips inside the unit could be burnt out or the thermistor that contols HI limit could be open.
Apr 29, 2011 | Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
My dometic RV rooftop air conditioner is leaking on the inside of the camper even after I cleaned the water condensation drain on top of the roof. What could be causing this? The fan is blowing the water...
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
154 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
