Turned on last night..came on for a sec (heard HBO ad), then nothing! the Red power light is on and flashing as well as the green light (which usually indicates the tv is off). TV wont turn on or off with remote. Tryed unplugging tv, and when u plug it back in goes to the same staus with the lights. Pulled out the Lamp, it looks good (just replaced about 9 months ago). and in past when it was the lamp the tv would still turn on and off...HELP
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
SOURCE: replaced lamp on my toshiba 50hm66 and still wont turn on
hello i'm not sure if i'm right but when you install these lamps you rght have reset the lamp counter
shaun
