Question about Maytag Washing Machines
Maytag centennial washer 1 year old has bad smell in it --worse when we use it....like a rotten smell
SOURCE: Rotten Egg Smell
Let me guess, you smell it when you use hot water to wash? sounds like it is more of a hot water heater problem with the rotten egg smell you mention. This happens when the "sacrifical rod" in your hot water heater needs replacing. Inside every water heater is a long magnesium bar called an anode rod. The sacrificial metal protects the tank from rust by corroding first. Once the bar disintegrates, however, the tank begins to corrode. You can at least double the life of your heater by replacing the rod before it dissolves completely ? every four years or so, depending on your water quality. Hope this helps. Joe
Posted on Jan 21, 2007
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Posted on May 30, 2007
  • 1294 Answers
SOURCE: Washing Machine Smell
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Posted on Sep 16, 2007
  • 16 Answers
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Posted on Dec 07, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Posted on Jul 18, 2009
The washer for our Maytag LS7806 has quit, but the dryer still works. A few weeks after we stopped using the washer, it started to smell of rotten eggs. I can't find a filter to clean, any ideas?
The bacteria in the washer part are causing the smell.
Give the inside a good wipe round with a damp cloth to remove any visible residue.
Leave the door and soap drawer fully open so that the inside dries out after a couple of days; that should fix it.
Jan 06, 2018 | Maytag Washing Machines
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
How do i fing out if my washer is still under Warr.? I have a Maytag centennial washer
The standard warranty is 1 year from date of purchase for all parts and labor. I believe the Centennial Series has a 10 year warranty on the wash tub (basket) and motor, parts only. So if your washer is over 1 year old, the pump would not be covered. If I may ask, why do you think the pump is defective? Can you provide the model number of your washer?
Dec 23, 2014 | Maytag Centennial Top Load Washer
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Rotten Egg Smell
Jan 21, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
