Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
How to remove plastic limiter cap on (H) carburetor adjustment
Homelite 14 inch chain saw, model UT10901A, need to turn carburetor (H) adjustment 1/16 turn counter clockwise but restricted by plastic limiter cap. How do I remove or bypass the limiter cap?
    Brigadier General:
  • 4,088 Answers
If plastic cap is present, it should just pop off with a thin sharp hook. Look carefully at the screw heads--they may be 'D' heads which require a special screwdriver and are supposed to keep owners from moving the screws (thank the EPA for these). Only authorized saw servicing dealers have access to these tools and therefore are the only folks allowed to adjust these saws. Being nonconformist, I made my own by drilling the center of a 1/4" rod, sawed off one side somewhat and welded a flat across the cut. Hope this helps!
Posted on May 11, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
I HAVE A HOMELITE XL2 CHAINSAW WITH A 12 INCH BAR, CAN I INCREASE THE BAR TO A 14 OR 16 INCH BAR.
Usually, yes. Take the saw to a service dealer who can fit a longer bar and proper length chain. You will need to keep the chain properly sharpened and adjusted to prevent extra load on the engine. Hope this helps!
Aug 16, 2010 | Oregon Scientific Oregon Bar And Chain Set...
Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Apr 17, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Sep 13, 2009 | Poulan Garden
Looking for an online user manual. Do you you
I tried Homelite UT10901A & Homelite Bandit here: http://www.arboristsite.com/showthread.php?t=72322&highlight=beg+manuals
You can join (free) and post your request. Be prepared to be flamed for owning a "homeowner" saw. Lou
Aug 23, 2009 | Homelite Garden
Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
Jul 19, 2009 | Homelite Garden
Need Manual
Go to jackssmallengines.com/searchdb2.cfm Click parts look up, click parts look up again, choose homelite under select OEM, click homelite, click chain saws, follow down list to model no. and click on it.
Apr 09, 2009 | Homelite Garden
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
1,902 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
