Question about NRS Jones Stephens Corp. S01-050 Shower Stall Elbow
My shower stall has a crack on the floor,i dont know if there is a apn underneathe to prevent rotting on wood
    Scholar:
  • 102 Answers
If your shower stall has a crack in the bottom, you may be able to see if it is getting the wood wet by looking under house. But even if it is not leaking there now, it will eventualy become a problem. I would suggest that you make some repairs or hire a proffessional soon. I hope this helps.
Posted on May 11, 2010
I have a dark spot on my hardwood floor under a window. There is a small change in surface texture, but no cupping or cracking. Any thoughts?
the indications are that there is moisture getting into the timber and causing wood rot
as it is under a window I would be investigation where water could be getting in past the outside cladding and getting to the edge of the floor at the wall in that area . possible leak in at the window sill ends /area
Sep 01, 2016 | Vacuums
How to reinforce a flexing fiberglass shower floor
either replace with a precast concrete shower base or fill the area underneath the fibreglass shower with expanding foam. You would have to put a small box section around the drain for access.
May 20, 2016 | Home
Floor sags slightly with wt. of a person. Is there something that can be inserted under the tub floor?
You likely have dry rot, caused by a leak. Very best thing to do is have a competent contractor look underneath and confirm what really needs to be done. You may need to replace floor joists, fix the shower pan, etc.
Oct 12, 2015 | Plumbing
60x34 walk in shower wall unit white
For warranty issues you should probably contact the factory which would be Sterling directly.
US Parts Center
Apr 28, 2014 | Sterling Ensemble Bath/Shower Unit 60" x...
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
Recently installed Toto toilet by a qualified plummer(twice) it still rocks side to side and back and forth. Floor is level. Toto Toilet Aquia11
Qualified? Plumber? sounds like it needs to be shimed,because not all floors are exactly level,or castings of toilets exactly perfect.Doesn't sound like the handyman knows what he's doing.Shims available at home depot--plastic-don't shim with wood-it will rot.I've used various coins to get right thickness.Be careful tightening bolts,you'll crack bowl.Find a legit plumber licensed
Feb 15, 2011 | Home
Install plastic (fibreglass)shower floor tray. Do
no, they are designed to require no support. You may use small columns of expansion foam for added strength, but do not fill entire space with foam as it will raise the whole floor upon expansion.
Sep 22, 2010 | Home
I have just had a new shower enclosure fitted which has has to be built up off the floor to allow for drainage. This has left a 3" gap along the bottom from floor to shower base. Where can I get a piece of...
Hello. Just go to home depot or lowes and get 2-3 spray cans of expandible foam. If you have acces to the opening between the floor and shower floor spray it around the gap. If not, Just use a small drill bit and make some holes around the wood frame and spray it. These foam will secure the shower and also will prevent the shower floor to crack it.
Aug 30, 2010 | Home
Older shower stall with crack in floor
yes go aout zone and pick up a fibber glass repair kit or some 30 min epoxy
either one of thesr will fix it
the floor will will have too be sanded before appling and after its set up
Mar 29, 2009 | NRS Jones Stephens Corp. S01-050 Shower...
NRS Jones Stephens Corp. S01-050 Shower Stall Elbow Logo
79 people viewed this question
Top NRS Plumbing Experts
Donni Steen
Tom Chichester
Are you a NRS Plumbing Expert? Answer questions, earn points and help others
