Question about Asko D1776 Stainless Steel Built-in Dishwasher
ASKO dishwasher my dishwasher came on spontaneously and keeps running first (drain, I believe) cycle. It stops when I unplug it (of course- no power) but sturts immediately when I plug it back. Error message is displayed
    Sergeant:
  • 351 Answers
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Posted on Mar 28, 2008
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
406 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
