Question about Bose Wave Radio
In line fuse
Power surge blew fuse - cut off all power - radio clock turned on when i jumped the fuse - did not check radio yet - need to determine correct replacement fuse - and where to buy it - the board shows a diagram indicating correct placement of fuse with the following specs "75A 250V " .
I would appreciate any help.
peter
  • 2 more comments
  • pheadar Apr 01, 2008
    thanks - i already found the correct fuse at radio shack ($2.99) (.75 a - 250v) and soldered it to the board - radio is good as new - hard to believe fuse was hardwired to board - makes replacement more complicated than it should be!
    pheadar
  • Anonymous Apr 04, 2008
    I believe that I have the same problem, but I cannot get the case apart to replace the fuse. I removed the 3 screws and the case comes partially off the base, but I cant get it any further. Anything obvious that I am missing on getting the case apart? Also, I cant believe the fuse is not easily replaced
  • Anonymous Jun 14, 2008
    Relative gave me an early 90's wave radio that is "dead". A call to Bose tech. assist. was useless, as the rep. was more interested in selling me a new and upgraded unit for hundreds more. I did a review of the web, noted fuse problems, metered the fuses and found one blown fuse. So, next I will go to radio shack (Bose rep. said repairs and parts are unavailable from both Bose and authorized dealers) and, hopefully, for less than 3 dollars I will have a functioning radio. Why would anyone buy from a company that will not assist the owners of its product?
  • Ciekawy Jun 27, 2008
    Radio wave no power what so ever. Opened plastic cabinet (two screws underneath at the back, one screw in CD compartment, and two plastic latches on the front where the two parts of the plastic shell meet) and found that the soldered in fuse blown. It would be necessary to remove printed circuit board in order to replace the fuse. Does anybody knows how to do it?
I have the same problem. To get to the circuit board remove all the screws from the bottom of the Wave radio. At least that is what we did, but ours is a really old model. There are two screws if you are looking from the back to the front on the front right corner that secures the bottom to the interior chassis THROUGH the circuit board. Careful! if you unplug all the gang connectors and those two screws are out it will come apart. My question is Where is this blown fuse located on the circuit board? I have two glass fuses in fuse holders that are ok.
Posted on May 22, 2008
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Posted on Apr 01, 2008
I have a 2002 gs 300 and my whole display,radio, time are out. There was a spark when getting a jump and my gauges went blank. Worst case scenario my motherboard is out what is cost to replace that?
Hi like to try to answer your question before buying any expensive parts check your fuses under the hood, cause it sounds only like a power surge n blew only one or two fuses a common thing when jumping a car
good luck.
Nov 24, 2014 | Lexus Cars & Trucks
Idiots jumped my truck wrong blew all my fuses witch fuses power the radio, clock, over head lights
You can replace all fuses and relays but hope the computer ECU survived otherwise it is a big and expensive problem.
Mar 10, 2010 | 2002 Toyota Tacoma
Speedometer gauge/climate control lights dont work
Look for a dimmer wire,, sounds like your radio dont have the option for the car dimmer switch,,
the power for these lights run through the dimmer wire for the radio. ether its not hooked up or the radio dont have the option for it.
there is a way to bypass the radio dimmer option,, BUT you have to know what your doing or you could fry something.
look for Car Radio Illumination/dimmer Wire: should be Green.
Nov 27, 2009 | 2005 Scion xB
How do I determine the correct fuse associated with the radio, clock, and side windows on my 1997 Toyota 4Runner?
Check out the instrument panel fusebox. Fuse 18. ACC 15 A: Car audio system, power antenna, clock, power rear view mirror control.
I also have clock removal instructions on my website if you need them www.autoclockrepair.com
Oct 13, 2009 | 1997 Toyota 4Runner
No Radio No Clock.Help
When you cut the wires you most likely blew a fuse.
May 18, 2009 | 2003 Mitsubishi Eclipse Spyder
My main fuse blew from a loose cable, I replaced the 100 amp fuse
Check ALL your fuses (under-hood as well as in-dash). It is not uncommon for a current surge in excess of 100 amps to blow other fuses.
Apr 14, 2009 | 2000 Hyundai Elantra
Think Power surge blew out radio. Can it be fixed?
The fix may be as simple as replacing a fuse. Location varies by model, but each has an internal fuse on one of its circuit boards. SAFETY NOTE: It may seem obvious, but be sure to disconnect power from the set before you open the case.
If the fuse is not the problem, you will need to seek professional repair. Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Feb 09, 2009 | Bose Wave Radio
Bose Wave Radio Logo
1,099 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
