Question about E-Machines eMachines Desktop PC
I want to connect the front panel usb's , micro phone and head phone sockets to a cognac 20000731 motherboard but I'm not sure which plug goes to which pin
  • 75 Answers
The socket coloured with green is of head phones and pink is of microphone
Posted on May 09, 2010
How to connect front usb?
Use Port Y and BB for Front panel USB connector.
Refer to page 12 and 13 of the manual
Intel BLKD101GGCL Specification Board Components Shown In Figure 2
Jun 03, 2016 | Intel Desktop Board D101GGC - motherboard...
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Front pannel usb connection for Motherboard (945GZM775SE)
Ok, what about the front panel usb connection??
If they don't work, you can always plug in a usb adapter into one that does work to get more usb ports.
May 16, 2012 | Biostar 945GZ-SE Micro Socket 775...
I use intel945gcnl mother board.how i join front panel audio in and out.front panel usb connected but audio how. please explore with a diagram........sorry for my bad english
Inside your computer, look for the cables that are attached to the front panel audio and front panel usb, on the end of both cables you will see a rectangle plug, on your motherboard you will see ports that are designed exactly for the two plugs I have mentioned, at this point you plug them into the relevant ports. It is worth noting that these plugs are slightly different from eachother, thereby preventing you from plugging them in to the incorrect sockets.
If you have any more questions, please do not hesitate in asking,
Chris
Sep 10, 2011 | Intel Motherboard
Hi my front USB r not working
maybe due to lose connections inside the case or can happen with USB driver problems (reinstall motherboard usb driver)
Jan 02, 2011 | Biostar 945GZ-SE Micro Socket 775...
No sound thru front socket
check in audio maneger disable front panel detection or check connecting cable in side tha cabinet which connect the motherboare and panel
Jun 24, 2010 | Biostar 945GZ-SE Micro Socket 775...
E-Machines eMachines Desktop PC Logo
74 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
