Samsung color 510 printer
I have the laser printer and when I am printing their is a line going down on my paper, I replaced the cartridges.
What should I do
1. Check the roller inside the cartridge
2. Check the fuser - It may have to be replaced.
Have you tried to clean the inside of the printer as well as the rollers?
Posted on Mar 28, 2008
SOURCE:
Colored stripe down the edge
Sounds like the transfer belt could be bad, however if your lines are just 1 color than replace that color toner cartridge
Aug 05, 2012 | Brother HL3075CW - HL-3075CW Wireless...
I HAVE A PAPER JAM. ALL THAT IS LEFT IS A SMALL PIECE OF PAPER. PLEASE TELLO ME WHAT I DO NOW.
It's almost definitely a bad exit sensor (known design flaw by Samsung). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Nov 04, 2010 | Samsung CLP-315W Laser Color Printer
During printing the printer prints a colored band down the length of the paper, the band moves across the paper...each sheet the band is in a different location
I had a similar problem where it would print the a few color lines on the edge of the paper going the full length of the longest side. Turned out to be the transfer belt.
You can first try to uninstall your drivers and reinstalling them from the cd or download them from the samsung website.
Apr 30, 2010 | Samsung CLP-510 Laser Printer
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
I am out of ink on 3 colors, can i print with just black, the printer will not print
Probably not.
Replace the cartridges with Samsung factory new cartridges.
Do not waste your time and money with refilled cartridges or third party cartridges.
Don
Feb 19, 2010 | Samsung CLP-510 Laser Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
Samsung clp-510
may be the drum of your laser cartridge must be end of its life orwaste toner collection unit must be full.
Aug 07, 2008 | Samsung CLP-510 Laser Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Print Quality problem
Faulty Drum Unit
Contaminated Fuser
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Open Questions:
95 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
