Flip the thing unside down...the cover theat is over the brush comes off with abotu four screws...then you can pop the brush up and out....take off the new belt and then get the new belt around the motor shaft, then around the brush... it will stretch hard to get it back in place....secure the cover and your good to go!!!
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at [email protected] if you have any questions about the repair!
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt #
38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853508 Generic problem for all Vacuums New main belt alignment for Posted by donlee300 on July 29, 2008 New main belt alignment for Hoover Windtunnel Mach 6.1. Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley. Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you may have a broken or cracked motor mount and the motor has shifted and that could be the reason that the belt is not running straight and aligned properly – if you have the vacuum less than one year – something like this would be covered under the Hoover factory warranty and to contact an authorized Hoover vacuum cleaner dealer in your area or to call the Hoover factory cust serv @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.hoover.com Telephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST Thanks, Don the Vac Man Go Ahead. Use Us.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=744864 Hoover Beater bar belt Posted by rubyspider on Jul 05, 2008 I need help installing the beater bar belt Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. All you need to do id to remove the bottom plate by removing either the screws, clips or levers and the bottom plate should come right off, and then you can get @ the belt – if not then the top cover will come off and then you can serv it from the top if needed. Then you can lift up the one end of the Hoover brushroll and then slide the new belt on to the pulley side of the brushroll and then use a belt puller or a screwdriver with a hook on the end and then pull the belt onto the motor pulley. Then track the belt in a straight line. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.hoover.com Telephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST Thanks, Don the Vac Man Go Ahead. Use Us.
Here's an instructional video that we made showing how to change the belt on a Hoover Windtunnel upright. If your model is not a self propelled model, basically follow the same insturctions, expect instead of placing the belt over the pulley, just put the belt through the roller brush, and stretch the roller brush back into the agitator housing.
Please feel free to send me an email if you have any other questions. My email address is [email protected].
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
