Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore Progressive vacuum burning smell
I have a kenmore bagless progressive vacuum with direct drive. I smell a light burning smell and it is not sucking that great. Do you know what this may be?
  • 184 Answers
SOURCE: kenmore Progressive 25614 vacuum
check the reset button on the brush assembly which is also called the power mate. if not then take it to your local sears repair center. if it is the pc board. sears has them in stock. I think it is about $7 for the part.
Posted on Feb 05, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: Why is it not sucking? Why the loud noise?
It's plugged up. Maybe pet hair? Take the hose off and run something through it, clean all the filters, clear all airways if necessary
Posted on Sep 07, 2009
  • 6 Answers
SOURCE: kenmore progressive 300 smells like it is burning
These vacs use Ametek motors which are practically designed to fail. Frequent complaints are a burning smell and louder than usual noise in the canister. The problem is the poor quality
bearings Ametek uses in the motors in the units. They have low-end ball bearings with a nylon "crown" that breaks up and gums up the bearing. Further the fan end of the motor is a bear to get to because of poor (intentionally?) design. With great difficulty I WAS able to remove the fan and housing and inspect the bearing. Since finding a replacement is too much trouble or impossible, I cleaned up the ball bearings and switched the bearings on the two ends moving the remaining good one from the brush end to the fan end where I assume the load is. I packed the damaged one with grease.
Now the motor runs smoothly. I doubt however this jury rig will last very long. It is very irritating to toss a $120 motor because of a failed bearing. Kenmore and Ametek should be embarassed but I'm sure they are NOT!
Posted on Nov 07, 2009
I have the model 36932 with direct drive. lately, there is the distinct smell of rubber when starting up and running. There is no belt on this machine. What could be causing the smell? roger
Check that the rotating brush is not seized and the belt is not slipping on it or the motor drive shaft. The belt will burn through if the machine is left to run any longer.
Feb 02, 2011 | Kenmore 31913 Progressive Direct Drive...
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
Our kenmore progressive with direct drive makes real loud noise when using and i am sure we have the bag on the right way
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Kenmore 31913 Progressive Direct Drive...
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Progressive drive bagless and beltless sweeper (purple) that has a burning smell when running, what could it be?
most likely the brushroll motor which is located inside the brushroll. This machine is one of the worst designs produced by kenmore, usually the brushroll motor only lasts 2 to 3 yrs.
Jan 06, 2010 | Vacuums
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
125 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
