Question about Craftsman 20 Hp 42" Deck Lawn Tractor
How to adjust lawn deck it too low on one side its 20 hp 46 deck
  • 35 Answers
Attached you will find instructions for this task on a DLT-3000, 48" deck. It should be quite similar.how to adjust lawn deck it too low on one side - ae27863.jpgea7530a.jpg
Posted on May 09, 2010
Why does the deck wiggle back and forth and scalp lawn on one side?
perhaps the anti scalping wheels need adjusted or don't lower deck so far .
May 11, 2015 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
When replacing double stack drive/deck pulley,how do you keep it from scraping deck/20 hp,46 cut,02 model,yard machines??!
MTD part number 950-0960A This is a spacer that goes under the pulley stack. It should help to keep the pulley from rubbing on the deck. Hope this helps.
Apr 01, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
May 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 20 HP Sears riding mower with 42" deck. Something has caused the right side of the deck to sit lower. It literally sits on the ground when lower to #1 position.
There are deck leveling adjustment bars located on most lawn tractors, most are equipped with a large plastic wing nut. There will be one on each side, with the mower off, lower the deck to the lowest position, loosen the wing nuts on each side, then re-tightnen. There is also a possibility if this is not the way your deck is levelled, there will be a deck hang wire/rod, however those are usually found on zero turn style mowers.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Nov 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need belt configuration for 46" deck of craftsman mower
there will be a sticker showing the belt routing, on the back of the deck [rear] in the middle, or on the left, top side of the deck
Aug 30, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt diagram for craftsman 46" model#917258691 I am replacing the secondary belt
belt routing diagrams are sometimes on the underside of the running board [so when you are laying on your back, you can look up and see it, left side usually]. on a 46 inch deck, it's probable that the diagram is on the rear, center of the deck, you can see it by going behind the tractor, kneeling down and looking forward at the deck
Jul 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
444 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
