Question about Dell Inspiron B130 Notebook
Cannot load the windows os, all i get is a black screen after the post
    Genius:
  • 1,354 Answers
The problem is your trying to install windows XP it need sata drivers or you have to enable your sata drivers
then only u can install windows
Posted on May 09, 2010
Desktop not accessible/ full black display
Presumably you see items on the screen while the os is loading and you are able to see the login prompts?
If this is a windows OS start it up in safe mode (tap f8 when first turned on to get a boot menu) to see what happens. Sounds like a resolution issue. If windows opens in safe mode look for evrror messages in the system logs relating to graphics gards or look at lowering the graphics resolution, also try attaching an external monitor. Post back if you get stuck
Dec 09, 2013 | Toshiba Computers & Internet
Gigabyte GA 8GP NXP DUO
Hi, A couple of possibilities/things to try: 1. After reset & remove battery, go to the CMOS/BIOS setup and load default configurations; 2. "...loading windows ... screen goes black..." are you installing a fresh clean Windows or are you using an image/recovery of your old Windows. If it's an image/recovery, it is possible and very likely that the OS is no longer recognizing the motherboard as the old motherboard because of the BIOS update. Perhaps you should try a clean fresh install. 3. try booting in to a simple bootable diskette/CD of FreeDos or Dos 6.2 or variants, just to check if the motherboard will finish POST and BOOT. Post back that we can figure out other possibilities or should you need further information. Hope this be of some idea/help to you. Good luck and kind regards.
Sep 09, 2007 | Intel Motherboard
What are the reasons for system failure
Could be hardware or a bad load of the OS. Does your BIOS post? Unplug the disk drive(s) and watch your screen. It should present several screens as it boots to a black screen. Run diagnostics on your HDD. If good, reload your OS.
Aug 22, 2013 | Computers & Internet
Screen goes black just after windows logo on a E-SYSTEM sorrento 1.
Your monitor display settings are no longer set (synced) with the upgrade. Boot into Safe Mode by pressing F8 during boot and lower the screen resolution.
You will have to check Display drivers in Device Manager, and make sure they are loaded.
Sep 25, 2012 | Computers & Internet
When my computer starts up after the windows logo loading screen the screen turns black and then my keyboard and mouse stop responding and the screen stays black thats it
Press F8 key after post boot screen and before windows booting, dos screen will come from there select safe mede booting, computer will boot in safe mode
1) Click On start
2) Go to All programs
3) Go to Accessories
4) Go to System Tools
5) Select system restore
Sytem restore window will come there you will select restore my computer to the earlier time, you will get calender on the screen there you have select any highlighted previous date
After restart your computer will be ok.
Apr 01, 2010 | ASUS P4B533-VM Motherboard
Hello, I have a Sony Vaio VGC-V3M and I have just a black screen after starting it. I can hear windows loading, and I get the vaio logo, then the Windows XP logo but then blackness. I can get the Bios...
If you can see the windows logo and get into the bios then it is not the graphics card.
Most likely cause is the os itself, just after post press F8 repeatetly until you have the boot mode page open and choose safe mode, in safe mode do a system restore, goto start bar, programs, accessories, system tools and system restore, and start from a resent restore point. This can can take a while, so be patient and let the computer restore itself until you have the windows screen up.
If the restore dosent work, goto safe mode again, right click on my computer goto properties and enter device manager, in there under display adapters click on the plus sign and uninstall the graphics card, reboot. hope this helps post back if need farther help.
Feb 15, 2010 | Sony VAIO VGC-RB38G PC Desktop
My notebook wont load the OS
Try in safe mode with command prompt and try to do a system restore.
IF not booting in same also then the only way is repair the OS.
Dec 09, 2009 | ASUS Computers & Internet
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
Black screen and blinking underscore before loading OS
chipset drivers that are loaded onto the harddrive are not the same as the ones in the "new" computer you put it into.
The only way to do that is format the drive and start from vanilla.
This is very common. -Jeff
Feb 04, 2009 | Gateway e-4200 P2 400MHz Tower...
Dell Inspiron B130 Notebook Logo
43 people viewed this question
Alun Cox
