Question about Garden
Do you need to saturate the sponge surrounding the
Does any one know if you need to saturate the sponge surrounding the air filter with oil on a Snapper Lawn Push Mower before you replace it?
    President:
  • 2,468 Answers
No it is not necessary but you can if you so desire,just dont drown it in oil as it will capillary attract the oil into the sponge by itself
Posted on May 09, 2010
I have oil in my air filter box on my sugar forested what do I do?
Replace the PCV valve and check for restriction make sure the pcv has vacuum and is working. A little bit of residule is not a problem unless it completely saturated. if its is completely saturated check the oil level and use the proper oil filter and proper weight.For now lets not get alarmed.
Feb 28, 2012 | 2001 Subaru Forester
1989 yamaha pro hauler. How do I change the rear axle oil. Also where is the oil filter. Also the air intake sponge is soaked with oil, and it has a ton of oil in the box where the air intake sponge is......
The axle drain is on the bottom of gear housing. The fill is on the side. On the side of the engine there is a round cover with 3 bolts, the filter is under that. Check your oil level, if it is high the oil will be pumped into the airbox. The filter can be washed with foam air filter cleaner.
Apr 29, 2011 | 2008 Yamaha Gladiator
Our mower is leaking oil from filter and we cant find the manual to figure out if the mixture is wrong - any advice?
Make sure the engine is not over-filled with oil. The crankcase breather is probably vented into the air cleaner canister causing oil to collect if the engine is overfilled. A similar condition can occur if the air filter is an oil saturated sponge and the filter wasn't allowed to drain excess oil. Don't worry about mixture problems if the engine is running correctly. Hope this helps!
Dec 09, 2010 | Garden
I lost my instruction manuel and i dont know how to put oil in the airfilter
pop air filter of.Carefull not to let anything get down into engine. Remove sponge. If theres 2 sponges then you need to coat the inner sponge. pour a little onto sponge and squeeze so it gets into all the holes. give it the sponge a good last squeeze holding over jar to get rid of excess as this will prevent air from entering engine. Fit air filter back on. Good idea to have a few spare so when one is used others can be washed and dryed. Either wash in wasing up liquid and dryed or nitro fuel and dryed.Hope this helps.
Aug 06, 2010 | Tornado 110 Nitro 4wd 2 Spd Off Road S30...
Where is the air filter on Craftsman Model 917377660 lawn mower
If you have a briggs or a tecumsen it is mounted on the side mounted on the top side of the carburator, one is a round cylindrical filter with a steel or plastic mesh surrounding and the other is a rather flat 3"X5" filter also mounted under a single center screw and cover.The third type is an oil bath type sponge filter, mounted directly on top of the carburetor on the side of the engine, you replace the sponge and clean out the metal housing held down with one long screw through its top center.
Jun 21, 2010 | Garden
Do I saturate the air filter with oil?
Okay...yeah, your question came up as "Generic Leaf Blowers" so I had to ask. The answer is no, you do not have to saturate the air filter with oil.
Oct 29, 2009 | Garden
Do you use air filter dry or saturate with oil
The Poulan Wildthing air filter should be installed dry. It can be cleaned with warm, soapy water, rinsed well, dried thoroughly, and then reinstalled if there are no breaks in the filtering media.
Aug 04, 2009 | Poulan Garden
Where is the air filter? How do I clean it?
The air filter should be connected directly to your carburetor.It should just be a sponge in a container connected to the carburetor.On most mowers it is one screw to remove the cover.You remove the sponge,and clean it with soap,and water.Dish washing liquid should work fine.squeeze all the water out of it.then soak the sponge with motor oil.then squeeze out most of the motor oil.The motor oil traps the dust.Then put your slightly oily sponge back in its holder,and close it up. Your done.
Jun 05, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Oil blow out the breather
An overfull oil tank will do it. Even if not overfull just about all harley's will blow oil out the air filter. Unless there is a bunch of oil coming out, it's not a problem What I've found is that the air filter eventually gets saturated and then starts to leak through. The level in the oil tank doesn't seem to matter. If you change the air filter the problem goes away, until the new one gets saturated and then it starts all over again. My plan is to get a K&N air filter, which you can clean yourself and save having to buy a new air filter every 4,000 miles or so.
Nov 20, 2008 | 2006 Harley Davidson XL 1200 R Sporster...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
