Question about JVC AV-32980 32" TV
Picture shows snow and fuzz on channels JVC AV-32980
M JVC TV is showing snowy pictures from channel 2 to 6 and is static from channel 7 to 28, but once I get up to the higher channels from 58 and up the picture is clear and perfect. What is the problem with the TV?
    Scholar:
  • 67 Answers
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Posted on Mar 27, 2008
How do I watch a DVD with this tv. It seems like it is connected right but just showing static
Hi. By static, do you mean 'snow' image ? DVD players must be connected to AV inputs and selected as an AV signal, either by using the remote control, either using the local controls in the set itself. If you see, what you call static, means that your TV is on "a" channel without areal input. (antenna inputsignal).
You can use the local TV channel button (-), go all the way down below channel 1. There the AV inputs are located. Good luck.
Oct 13, 2014 | GE 27GT616 27" TV
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
I have auto programmed the television, but it only shows white snow no matter what. I have also fine tuned it as well. The model is shownic lc26ce80r. Can you help
My personal guess would be that there is no signal coming through to your tv or the wrong signal coming through. I have the opposite problem...we get picture (snowy) but no sound except that of snow and the Audio/Sound options are NOT helpful. Wish I could be of better help.
Jan 28, 2011 | JVC AV-20220 TV
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
Suddenly all of a sudden
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Apr 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
JVC AV-32980 32" TV Logo
167 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
