Question about Garmin Nuvi 660 GPS Receiver
Speedo Is there a fix which can show the speedo when navigating rather than just the ETA?
  • 4 Answers
That is on my wish list as well. Hopefully Garmin would put that in a software update
Posted on Apr 05, 2008
Why speedo has stoped working?
Hi Anthony, The link below is a youtube video showing how to fix the speedo on your car.....CHEERS..
Fixing The Speedometer On Your Car
Apr 17, 2016 | Opel Corsa Cars & Trucks
Has anyone ever heard a a speedo not showing the Total klm's but everything else works OK, if so can you tell me if there's a fix for it, besides buying another one??
Dont know the MV Augusta specifically. Assuming it is not a digital speedo, is probably a stripped gear in the speedo. Probably cheaper to replace it.
Oct 30, 2014 | 2008 MV Agusta Brutale 989R
Speedo problems
Get the sensor and speedo checked out, there is no quick fix, the information is electrical so there is either a problem with the sensor or a failed reciever in the speedo. It could be as simple as a bad connection at one end or the other, that may be worth investigating first though.
May 23, 2012 | Motorcycles
The speed shown on the speedometer is not accurate on my Yamaha XT125R - -When travelling at 30MPH -The speedo shows 38MPH -When travelling at 40MPH -The speedo shows 52MPH -When travelling at 50MPH - The...
If the speedo gear is in the front wheel a different wheel would have different gear and mess up the speedo but I'm thinking the gear wouldn't mesh with the old speedo cable teeth.Check a shop manual for stock number of teeth on rear sprocket and tranny sprocket,that will tell the story.While your at it check the stock wheel size compared with what you got.Of course it could be bad speedo.There's springs in there that run needle, so?Maybe borrow one and try it out.Good luck.
Mar 25, 2010 | 2006 Yamaha XT 125 R
Speedo shows 0 when moving on 2002 model
follow the speedo cable make sure it properly in place on the front wheel and speedo dial and if it is broken you will need to replace it or have it fixed
Dec 13, 2009 | 2001 Triumph 955i Speed triple
The speedometer n my 1999 Sportster 1200 has stopped registering. How do I fix it?
This depends on whether it is an electronic speedo or a mechanical speedo.
The electric speedo has a sensor near the rear of the engine. Sometimes a very small piece of metal will get stuck on the end of the sensor and the speedo will stop working. Remove the bolt holding the sensor into the engine case and carefully pull the sensor out. Wipe it off and reinstall it. If the speedo still does not work, it's probably something in the speedo itself.
On a mechanical speedo, a cable from the front wheel drives the speedo. The cable or the speedo drive unit may be bad. To check the cable and drive, lift the bike off the ground, disconnect the cable from the rear of the speedo. Turn the front wheel and see if the cable is turning. If it is, it's probably alright. I'd still pull the cable out of it's housing and lubricate it with some grease. If the cable is turning, the cable and drive unit is alright. The speedo may be broken.
Jun 15, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
My speedo always shows 0,any ideas on what it might be?
what type of bike is it. More than likely your speedo is cable drivien, you can check by following the wire from the back of the speedo to your front tire, if it is cable driven you may have broken the cable inside, this would probably be the cheapest and easiest fix.
Apr 15, 2009 | 2005 Suzuki GSX-R 750
Garmin Nuvi 660 GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
