Question about Jenn-Air JLG7130A
I have a Jenn-Air gas grill model #720-0061-LP it has 3 brass burners and a rotisserie burner on the back wall. the flame from the middle burner is shooting back into the knob causing issues with the burner and the knob becomes to hot to touch.
    Problem Solver:
  • 16 Answers
I have had the same problem before with same exact grill. The burners get clogged and the gas pressure backs up. I have had this actually split a gas valve and the plastic electronic igniters do not have a chance withe the head. Call nexgrill and get all new burners under warranty. This will solve the problem for a while. The latest burners that I received in Aug 2010 are 1/2 inch shorter and may solve this problem. You may want to buy new gas valves since the excess heat in this area may have damaged the valve. Since 2004, I am on my 5th set of burners, 2nd set of gas valves and 3rd electronic ignitor. May just recycle grill and get a Weber or go with charcoal.
Posted on Aug 25, 2010
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
Loss of gas pressure to burners on Jenn-air Model #720-0062-LP
If you're confident that you have adequate gas in the tank. turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Once connected, open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners the same way. Do all the flame heights now look correct? If so, you solved the problem. Remember to always open the tank valve very, very slowly.
If the above didn't solve the problem, you are either low on gas or the hose/regulator assembly needs to be replaced. If replacement is necessary, you can find the hose/regulator assembly at any home center or hardware store that sells gas grills and accessories. Take your old one with you for comparison purposes.
Hope this helped you solve the problem. Happy Grilling!!
May 02, 2011 | Jenn-Air Grilling
Need help re: replacing igniter of Gas Grill
If it is like mine, you have to remove the front control panel on the side burner and the front of the side shelf. Remove four screws behind the fronts below the shelf/burner and then you will have access to the screws to remove the main control panel. Be careful with all the hoses and gas piping. If the electronic ignitor is melted like mine(i am on #3), you have more problems than the igniter. I had to replace the burners and the gas valves to stop the flame from "backing up" into this area. Hope this helps.
Jul 10, 2010 | Jenn-Air Grilling
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
What are the btu ratings for a jenn air model 720-0100 ng grill. i am converting this to lp gas...
does not matter just change out the orfices on all burners and back burner even if you have a IR buners, the orfices let enough gas in for your grill call jenn air they will sell you the kit to convert it over
Jul 29, 2009 | Jenn-Air Grilling
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Grilling Logo
727 people viewed this question
Top Jenn-Air Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
