Question about GE A730 Digital Camera
I got an A735 GE camera and it says lens error and will not work. Is it worth getting fixed? Should I just get a new one. Thank you Ralph
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 13, 2011
Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 19, 2010 | General Electric A735 Digital Camera
Electric A735 Digital Camera: lens error cant zoom out...
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 18, 2010 | General Electric A735 Digital Camera
Help ge camera keeps showing lens error a 735
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 21, 2009 | General Electric A735 Digital Camera
LENS ERROR
My daughter had the same problem with her pink A735. I tried removing the batteries, resetting the default settings and every combination of buttons. Finally I grabbed the lens as it was opening and forced it out all the way. There was about 1/8" that it was short of being fully extended. This fixed the camera for at least a while, but it sounds like there is a problem with the mechanism as it clicks every time the lens deploys and retracts now. I suspect this is a short term fix, but if you are planning on tossing the camera out it is worth a try. This camera is only about a month old.
Dec 07, 2008 | General Electric A735 Digital Camera
GE A730 LENS ERROR
Hi sadloserx:
I am inserting this from a previous post, since this seems to be the same problem.
Also lens problems have to be described in full to see what is wrong. The following will give you some idea as to what I am saying.
This camera is telling you that there is a problem with the lens, either in the tracking, mechanical, or electrical circuit.
Try this: If the lens extends at all... then pull on the lens or push in to try to reset the tracking of the lens.
If the lens does not extend at all and makes noise, then it has problems in the lens gearing or motor.
If the lens makes no noise at all and you get the error with the shut down, then more than likely there is nothing that can be done.
Try this at your own risk:
With the camera off, gently hit the camera on a padded (folded towel) cloth on a solid surface, using one of the corners. This may jar the internal parts enough to make the camera work again.
BY doing this, you do risk damaging the camera beyond repair, however, if you have a camera not working anyway, it may be worth it.
I have fixed two cameras in the past this way. However, nothing is guaranteed.
Finally:
Find a repair shop and have it fixed. (These kinds of repairs can cost $150.00 or more). That will depend on your value and the age as well of the camera.
Sell it as is or for parts on a site such as Ebay.
Sep 25, 2008 | GE A730 Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
GE A730 Digital Camera Logo
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
