Question about General Electric Profile PSCS5RGXSS Stainless Steel Side by Side Refrigerator
GE side by side # PSCS 5RGX CFSS freezer shelf fall out
GE side by side # PSCS5RXGXCFSS freezer shelf is about a 1/4 inch too narrow and fall out.This is the shelf that is designed to site on the side rails, not one that goes into the holes.
    Problem Solver:
  • 19 Answers
I also have this problem with the same GE Profile series. The shelf sits above the "quick freeze" drawer. It's very annoying and I am looking for a way to fix it.
Posted on Dec 18, 2010
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the difference.next what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
The bottom shelf on our freezer is cracked from the back for about 2 inches. Can we use the freezer? The freezer is a top freezer on our GE profile refrigerator.
Drill a hole , at each end of the crack , to keep it from extending , then fill the crack ( and holes ) , with a white silicon caulk . Yes , you can use the freezer .
Nov 08, 2009 | GE Energy Star PDS22SIS Stainless Steel...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I did the tubing solution others mentionedand it worked great.. instead of the 1/2" OD 1/4" ID reinforced tubing. I bought Polyethylene tubing at 3/8" OD, 1/4" ID.
Cut the tubing into lengths that will fit between the rails, split with a utility knife down the whole length. Use a screw driver to force open the end and slip the tubing over the rail.
Pic attached shows the tubing cut along side and forced on to the rail along with a pic of the tag that was on the tubing in an inset. I bought a 25' roll because i was in a hurry and not paying attention. I did 2 shelves, needed something under 1' per side per shelf. so I used 4' total for the whole project.
Jan 20, 2009 | Refrigerators
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
General Electric Profile PSCS5RGXSS Stainless Steel Side by Side Refrigerator Logo
238 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
