Question about Esky Scale RC 3D Scale Helicopter RTF Radio Controlled RC Helicopter
I have just bought one with no instruction or battery on helicopter. Do i need battery pack and does charger plug into that?
    New Friend:
    Problem Solver:
  • 6 Answers
Yes of course!
You can't fly an RC Helicopter without battery.
It requires a good battery for both Helicopter and Remote.
Different HC Helicopters have different features.
You should have to buy an HC Helicopter with the whole kit. Be sure to read their descriptions or reviews before buying one for you.
For the best reviews about any RC Helicopter, visit the link: Venus Rocketry Your RC Helicopter Resource
Posted on Feb 07, 2017
The charger should plug into the model with a small connector coming from the remote
Posted on May 09, 2010
How can you tell if the helicopter is charging?
Well its either the charger or battery.... but by the sound of it the battery has failed... but just to check see if you can charge another battery with that charger or use a different charger on that battery....
Good Luck!
May 07, 2017 | The Toys
Cant get my gyros helicopter to charge what should I do
Check charger. Check batteries. Replace if necessary. (Note: battery ''packs'' can be rebuilt by taking them apart and buying replacement ''cells'' and solder them together the same way the originals are soldered together. Don't worry about ''breaking open'' the battery pack. It doesn't have to look pretty. It just needs to hold the batteries and fit in the charger (and the helicopter).
Jan 01, 2015 | Toys
Hello, I bought the fusion rc helicopter and I
If the battery does not recharge either it or the charger is defective.
Feb 22, 2018 | World Tech Toys GYRO Fusion 3.5CH Electric...
I HAVE A M1 HURRICANE HELICOPTER AND THE LIGHTS COME ON BUT IT WILL NOT FLY. CHANGED THE BATTERIES IN THE REMOTE BUT STILL DONT FLY.
Using a multi-meter, check the voltage of your helicopter's batteries to verify that you have a charged battery pack.
If so, verify that your battery is connected to your helicopters circuit. There should be a white plastic connector that plugs the battery pack into the helicopters on board systems.
If everything is connected correctly and you are reading a very slight voltage from the helicopter's battery, then most likely you are not getting a good charge coming from your power charger. If this is the case, go here:
http://www.fixya.com/support/t23269551-gyro_m1_turn_remote_but_get_spin_blade#answer
Hope this helps.
May 29, 2013 | Skytech M1 hurricane large 1:25 scale gyro...
The light on the charger for my helicopter syma S031 with gyroscope remains green even though it needs charging
Mine has also done this. The charger units for these helicopters are mass produced and therefore have a failure rate. I pugged mine in to the mains supply today and it sounded different, as in it 'popped'. The LED failed to light. When I plugged it into my models battery, it went green, even though the battery was low in voltage.
I metered my charger output and it is dead. My S031 is only two weeks old but to get to the shop is a nightmare so I may just open it up and repair it myself (I'm fine with electronics). However, I am not sure if my new battery pack is okay or not, so I run the risk of visually voiding my charger warranty. I have had issues with all of my Syma models and may just get a refund and move on to swashplate 6ch+ machines.
If your charger/S031 is new, I would suggest you return it to the store you purchased it from. Electronics this day and age are a joke and the quality control used is appalling, especially in cheap Japanese models alas.
The charger is sealed and will need to be broken open to access the electronics. Dangerous voltages are inside so I'd suggest you just return it for an exchange.
Jan 16, 2011 | xheli Syma S031 Outdoor RC Helicopter
Have helicopter charged new batteries in control. helicopter not responding. do you plug the cord to charger into empty slot in helicopter. manual not specific
Hello Susan,
What you need to do is to gently pull the cockpit housing off the post at the bottom rear and remove it from the machine. You can now access those connector plugs much easier along with noting where the trim screw is located.
Please note that the battery pack has a female connector while both your charger and the lead to the electric motor have male ends. Those male ends have two small pins within the connector and you need to get them oriented correctly with the round holes within the female connector.
Once you have established this, a dab of finger nail polish on the top side of each connector will make it easier to orient the plugs for charging the battery, or connecting the battery to the motor leads in the future.
Make sure to charge the battery for at least three hours, Do Not Overcharge.
Dec 24, 2010 | Jumbo RC JUMBO HELICOPTER
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
I have bought 2 Walkera heli, and I have had problems with both, the RTF is not, the manual tells you little about it , The LI poly battery almost blew up and the other bat wont hold a charge, what do I...
Did the charger come with the helicopters? It sounds like the packs are being overcharged or charged at too high of a current. Lipo packs are more sensitive to charging and discharging than NiCD and NiMH packs. I got my first helicopter last year so I don't have as much experience with them as cars and trucks, but I will help if I can. I have a Venom Beacon that came RTF with a Lipo pack and charger and I have not had any problems. I would also suggest a Lipo sack to put the packs in while charging. It would keep them from catching fire if they would happen to explode. Good luck.
Jan 01, 2010 | Walkera Co Axial 5 8 Metal Head Dragonfly...
Need an AC charger for my Hoverlite helicopter battery pack
visit your local deler if they have extra charger for your heli, if non is available, ask if any aftermarket ac charger can do. better yet, ask a friend who knows electronics to build a charger for you.
Jul 09, 2009 | Acer Aspire One AOA110-1588 Notebook
Esky Scale RC 3D Scale Helicopter RTF Radio Controlled RC Helicopter Logo
1,235 people viewed this question
Top Esky Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Esky Toy Expert? Answer questions, earn points and help others
