Question about 3DO Might and Magic VII: For Blood and Honor for Windows
Can't play Might & Magic on Vista
I can only play Might & Magic 6 on Vista, but none of the others will play. Help
I need the driver for the view cam A4Tech-PK-835, Windows 7 Home Premium. i can't find this driver! Please support! Kind regard, Mario Spreitzhofer!
I have checked the support site ofr your webcam:
Here's the product feature:
· Simply plug it in and play - no software installation required!
· Resolution up to 16 Megapixel
· Built-in Mic picks up sound from any direction with remarkable clarity
· Magic effects customize your personalized style
And here's you product requirement:
System Requirements PC with Pentium 800 MHz or above
256 MB RAM or above
At least 165 MB of free hard disk space
Windows XP, Vista, Windows 7, Mac OS X v10.4.8 and above
So basically its just plug and play no drivers needed
Check it out for yourself:
http://www.a4tech.com/product.asp?cid=77&scid=167&id=690
Good day.
Jun 20, 2011 | A4tech PK-835 (890891000025)
How do I play regional dvd's that the player is not tuned to. I have been trying to find a code but I am struggling. Can you help me?
Hi
You need to follow these instructions.
To unlock the Region Code on a Panasonic DMR EZ48 using a One for All - URC 7040
1. Switch on the player (make sure the drive select is DVD).
2. Select DVD on the URC.
3. Hold the magic button on the URC until the DVD button on the URC blinks twice
4. Enter device code 0490 on the URC, (DVD button blinks twice), URC takes control of the Player.
Point the URC at the Player and program the URC buttons using the following procedure:
1. Hold magic button until the DVD button on the URC blinks twice
2. Press 994 (DVD button blinks twice)
3. Briefly press magic.
4. Enter 4 digit code 1911 (DVD button on URC blinks twice)
5. Repeat steps 1, 2 & 3
6. Enter 4 digit code 1202 (DVD button on URC blinks twice)
7. Repeat steps 1, 2 & 3
8. Enter 4 digit code 0653 (DVD button on URC blinks twice)
9. Repeat steps 1, 2 & 3
10. Enter 4 digit code 1804 (DVD button on URC blinks twice)
11. Repeat steps 1, 2 & 3
12. Enter 4 digit code 1435 (DVD button on URC blinks twice)
13. Repeat steps 1, 2 & 3
14. Enter 4 digit code 1556 (DVD button on URC blinks twice)
15. Repeat steps 1, 2 & 3
16. Enter 4 digit code 1227 (DVD button on URC blinks twice)
17. Repeat steps 1, 2 & 3
18. Enter 4 digit code 1178 (DVD button on URC blinks twice)
19. Repeat steps 1, 2 & 3
20. Enter 4 digit code 1299 (DVD button on URC blinks twice)
21. Repeat steps 1, 2 & 3
22. Enter 4 digit code 1230 (DVD button on URC blinks twice)
23. Press the One For All URC buttons in the following sequence
1, 2, 3, 4, 5, 6, 7, 8, 9, THEN hold down 0 until "HELLO" appears in the display;
After about 1 minute the Player comes back to life as Multi Region.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Panasonic DMR-EZ48 DVD Recorder
I want vista service pack 6 theam
There is no Vista Service Pack 6. Vista has just service pack 2
Dec 31, 2010 | Computers & Internet
Have Sony 1GB memory stick "magic gate" that wont open on my laptop vista
ok
try
these steps:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 17, 2010 | Lexar JumpDrive Classic Portable USB Data...
I cannot play Blu Rays on my Acer (Vista) PC with
If the drive doesn't read any disc's you need to reinstall the drivers and verify you have the latest version. If the drive is ONLY having trouble with Blu-ray then i'm assuming it's the player that you're using; it may not have the right Codac's etc. Also, try multiple Blu-ray movies to verify it isn't just the one movie.
Jul 17, 2009 | Pioneer BDC-202 Blu-ray Burner
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
DOWNGRADING
Boot from cd and delete partion where vista is installed after that play set up .
Jun 19, 2008 | Microsoft Windows XP Professional With...
My refridgerator is not staying cold in the freezer compartment...
You have to loosen hinge screws as well as screws on opposit side. Then pry up plastic floor at front the two corners are a little difficult then slide it out.Backing up a little though none of this shoul be nessesary if you could come up with an amp probe as you can check amps to see if heater is comming on. Rember the amp probe only goes around one of the line wires to read meaning you would have to split wire about 6 inches.Heater should pull about 3 to 5 amps. If your heater is not comming on it could be the limit control or you are getting alittle short on freon. The limit control is at the end of the line on the magic chef frig. I hope i have helped to diagnose your problem. Fxit
Feb 02, 2008 | Refrigerators
400 watt amplifier not working
Disconnect all the speaker wires from the amplifier that runs the 6-speaker system. Switch off the amplifier or disconnect the remote turn-on wire, then re-connect it. Does the power light still flash with no speakers connected? If so, your amplifier is probably damaged. If not, then connect one speaker and see if it plays. If it doesn't, disconnect the first speaker and connect a different one. If the first speaker plays, continue connecting the rest of the speakers until you find the one that's causing the problem.
Mar 05, 2007 | Clarion APX401.2 Car Audio Amplifier
3DO Might and Magic VII: For Blood and Honor for Windows Logo
153 people viewed this question
Top 3DO Video Game Consoles & Games Experts
Paul
Gulkhan
Level 1 Expert
Tom Chichester
Are you a 3DO Video Game Console and Game Expert? Answer questions, earn points and help others
