Question about Toshiba Estudio 200L Copier
Pls if u have toner for toshiba copier - Toshiba Estudio 200L Copier
    Problem Solver:
  • 10 Answers
Use toner of any laser copier/printer which works with DUAL component projection (i.e; machine with Developer
Posted on Oct 18, 2010
  • sasheevja1 Oct 18, 2010
    Try Ricoh aficio Toner; Try (blind trial) Modi 1025/5223 toner
Increase the toner density toshiba copier e-studio 16
clean scanner drum unit change with good toner.
Sep 10, 2013 | Toshiba e-STUDIO 16 Printer
My toshiba copier720 error cf70 pls help me to solve this problem
That is a new toner motor abnormality. If memory serves there was a field mod released back when those were state of the art that dealt with that error code. Either way, sounds like you either have blown or about to blow your tonor motor. Time to holler at your nearest Toshiba Certified retailer.
Jan 16, 2013 | Toshiba E-STUDIO 720 Copier
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
Toshiba E-studio 166 error code c26
hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
Mar 07, 2012 | Toshiba e-Studio163 Copier
How removed toner indication still toshiba copier e-studio-181?
toshiba e-studio 181 toner indication patmanent still.
Feb 26, 2012 | Office Equipment & Supplies
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e studio 150 problem
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Nov 19, 2007 | Toshiba e-Studio150 Copier
19 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
