I have purchased Logitech X-530 speakers. How do I connect the three coloured leads to an HP PC (p6320). I am only getting sound from the 2 front left and righthand speakers
  • 4,281 Answers
There is 3 option hole in the back of hp pc.
pink-green-Blue
Green is for sound ,pink is microphone.and blue is for headphone
Connect woffer cable to Green hole of computer.
And connect speaker connector to woffer.Make sure cable connected properly to woofer.
Also go to control panel and sound property then make sure all sound speakers line enable and not muted.
Then check.
If still same issue then you need to open cpu cabinet cover then find motherboard then there is option for sound channel there is jumper settings for enable all channel of sound.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 09, 2010
My Logitech X530..only the front -left speaker works. Thank you.
Sounds like you have not plugged it in correctly! Have you connected the 3 mini plugs from the speakers into the adapter and then the 2 phono leads into the other end of the adapter and then the 3.5mm headphone jack into your device?
Oct 25, 2014 | Logitech X-530 70-Watt 5.1 Surround Sound...
I can only listen sound from the 2 front speakers while i have logitech x-530 5.1. My mobo has 3 colours at audio(pink.greeen.blue) and my speakers have green.pink.black. I only plugged green tho. Can i...
plug them all in pink/pink green/green blue/black
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 28, 2010 | Logitech X-530 Computer Speakers
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
When connecting the leads to the sound card do i plug one into the pc. and should all the speakers work straight away,I only have thee woofer and the centre speaker working.. LOGITECH X-530
There are leads that need to be connected to your computer for the Front, Rear, and Subwoofer speakers Not all motherboards have all of these connections Your Logitech manual shows how to connect the speakers correctly if you do not have all of the connections on your motherboard
Sep 14, 2009 | Logitech X-530 Computer Speakers
Logitech 5.1 x-530 speakers- sound from only two speakers at a time
http://es120290652650.epayments.co.uk/epages/es109454.sf/en_GB/?ObjectPath=/Shops/es109454_es120290652650/Products/130893 you will have to get one of these and if you havent already got three 3.5mm jack to jack leads you will need to purchase them aswell
the external sound device connects via usb to your laptop i bought one from the web site above myself excerlent soundcard use it for my dj'ing gigs top buy
Feb 15, 2008 | Logitech X-530 Computer Speakers
There should be a setting in your sound card, assuming it is a 5.1 surround card, that allows the card to split the signal from two input connections (normally the normal speaker input'green' and the mic input'pink')into the required 5.1 output.
Feb 08, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
