Question about Konica Minolta magicolor 2430 DL Laser Printer
How to change cartridge in magicolor 2500W? It says the drum cartidge is at the end of life.  I purchased what I thought what was right but now that I'm looking at it, I don't know what to do.  I have been on hold with Konica Minolta for over 30 minutes now.  Help!
  • JOHPAS May 09, 2008
    HAVE REPLACED THE DRUM AFTER MESSAGE 'DRUM CARTRIDGE END OF LIFE', BUT MESSAGE IS STILL THERE! WHEN I PRINT TESAT PAGE OUTPUT IS PERFECT.
    THE NEW DRUM HAS BEEN TESTED IN ANOTHER PRINTER AND IS OK. ALSO THE ORIGINAL WORKS IN ANOTHER PRINTER.
    Scholar:
  • 141 Answers
By pressing the front lever on the top of your machine it will open the top cover....But be very carefull DO NOT tuch the transfer belt (that's the thing who goes with the top cover). It's like a polaroid film....If you make a scratch on this you'll have scratch on every copy!!!!!
The first thing that you'll see on the bottom is the drum unit take it out gently and prepare the new one...Again, be carefull with the drum unit do not tuch the green cylinder(drum it self) and put the new one in the machine close the cover and a cycle of calibration will start...do not interrup this...DONE...
Posted on Mar 28, 2008
SOURCE:
Konica minolta magicolor 2350dl drum replacement
Was the new one new? Check the medal connectors located on the image unit anything medal and clean with alcohol and all connectors on the assy. the image unit goes in reseat properly Third party do not work use OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 11, 2012 | Minolta magicolor 2350 Laser Printer
My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Oct 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Drum End of Life
Unfortunately the manufacture has you over a barrel.
Have you contacted Minolta?
Ask for technical support sry not much help.
Nov 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
If one of the cartridges needs to be changed, the printer will recognize this and it will automatically rotate that cartridge to the front of the printer.
Open the panel and follow the instructions that are shown on a sticker on the inside of the access panel. Removing the cartridges is not difficult. They do have a slight groove near the top that acts as a handle. You may have to rotate the cartridge up as you lift it in order to get it to come out. DO NOT FORCE IT. Once again, please consult the sticker on the inside of the access panel for details on cartridge replacement.
If you need to replace more than one cartridge, press the rotate button to rotate the cartridges to the one that needs replacing and repeat the process.
DO NOT FORGET TO TAKE THE SEALING STRIP OUT OF THE NEW TONER CARTRIDGE BEFORE PUTTING IT IN AS THIS TAB CAN AND MOST LIKELY WILL DAMAGE THE PRINTER. (I've seen it happen.)
After you have replaced the toner cartridges properly, the printer should rotate the drum a few times to prime the cartridges. This is normal. You should see a readout on the LCD screen of the toner levels. (You may have to press a few buttons to see the status on them.)
If you need toner cartridges, head to your nearest office supply store such as Staples or Office Depot for replacements. (Staples will price match other stores if you give them proof of the other store's price.) When I last worked with this machine, the cartridges were still kind of expensive...but worth it for the quality that this machine gives you.
Good luck. :)
Cyryl
Nov 09, 2007 | Konica Minolta magicolor 2500W Laser...
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
111 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
