Question about Motorola Mobility H710 Bluetooth Headset
How to connect my motorola H710 bluetooth with my mobile
    President:
  • 1,118 Answers
You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location;
Hope you are able to sort your problems out.
Cheers! Carlos
Posted on May 11, 2010
SOURCE: motorola h710 bluetooth will connect to phone but no audio
I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
Posted on Feb 04, 2009
zohail
  • 1223 Answers
SOURCE: have motorola h710 bluetooth headset and no
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Posted on May 03, 2009
zohail
  • 1223 Answers
SOURCE: how do i sync motorola h710 bluetooth headset to my cell phone
here is the procedure kindly rate me well !
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H710/US-EN/_Documents/Static%20Files/H710_QSG.pdf
  • 5 Answers
SOURCE: i don't have the passkey for the Motorola H710
try 0000
Posted on Jan 04, 2010
vanherringto
  • 1738 Answers
SOURCE: How do I sync my motorola H710 bluetooth with my
Here's the instruction manual for the H710:
Motorola H710 download instruction manual .pdf 2MB
You'll have to check your owners manual for your Droid, but it's probably under Settings > Connections > Bluetooth (Turn on) > Discover (Pairing code 0000)
Posted on Feb 04, 2010
H710 I cant hear music on it?
H710 isn't A2DP compatible so you can't listen to music.
mark
Motorola Support
Apr 22, 2014 | Motorola Mobility H710 Bluetooth Headset
How do I sync my motorola H710 bluetooth with my Motorola Droid?
Feb 04, 2010 | Motorola Mobility H710 Bluetooth Headset
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
How do I add a 2nd phone to motorola bluetooth headset h710?
after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
Jul 03, 2009 | Motorola Mobility H710 Bluetooth Headset
The phone will read that it is paired with a Motorola H715, although the packaging identifies the bluetooth as an H710, but the phone never really pairs and will not work with this bluetooth. I have...
check out this manual for pairing up info
please rate me well for help !
Apr 18, 2009 | Motorola Mobility H710 Bluetooth Headset
Lost manual for my Motorala H710 can you advise as to where I can find one on line?
here is the manual for ur bluetooth headset
Apr 14, 2009 | Motorola Mobility H710 Bluetooth Headset
How do i sync motorola h710 bluetooth headset to my cell phone
Apr 02, 2009 | Motorola Mobility H710 Bluetooth Headset
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility H710 Bluetooth Headset Logo
1,077 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
