Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I have installed 2 of the 3 evaporators, the other evaporator I will install at a later date. I have power at condenser and evaporator. I cannot get the evaps to come on with the remote controller? Is there a jumper or something that needs to be inplace because I am only using 2 of the 3 units? I have installed a single zone unit also and that works fine. THX
  • 269 Answers
I guess the remote was 0k before you fitted the evaporators if so it may be a faulty control card, have you tried resetting the test button its inside the indoor unit near the electrical cover.
Posted on May 09, 2010
How to properly install my carrier siesta air conditioner,seems to build up condensation that wont evaporate ,justwant the proper installation diagram ,orhow to do it yourself kinda video
condensation doesn't evaporate
it runs off the evaporator fins into a drain channel and out side
it is possible that the drain is blocked
the action of an air conditioner is to remove the humidity (condensation from the room) and drain it outside
if it is to evaporate then the purpose of the air conditioner would be defeated.
Jun 30, 2015 | Carrier Siesta II TCA101B Air Conditioner
I just had central air installed. The evaporator coil was installed on the return air side of the furnace. Will this cause mold and condensation in my furnace?
Hello, the evaporator must be installed in the supply plenum to work properly and allow cool air to be supplied into the living space. I would call the company that installed it and have them install it properly.
Jun 12, 2012 | Heating & Cooling
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
MY GE ROOM AIR CONDITIONER AGH08AJG1 SWITCH BETWEEN COOL AND FAN EVERY 5 MINUTES APROXIMATELY NEVER SATYS COOLING UNTIL THE DESIRED TEMPERATURE IS REACHED
Check and clean the filter if found to be dirty. It is usually behind a decorative panel below the cold air output grates (when the cold air is on the top front).
The filter is behind the large, rectangular, slotted front panel. The evaporator coil is behind the filter. The fan behind the evaporator pulls the room air through the filter and evaporator coil where it is cooled and dehumidified. It is then discharged through the grates on the top of the front.
Direct the airflow from the unit up and away or left / right to prevent the cool air from being drawn in the front of the unit (this is where the thermostat sensor is located). Use the highest fan speed to help force the air away from the intake, too. Inspect the condenser and evaporator coils (condenser is outside and evaporator is directly behind the filter. Clean if dirty or icing over. Be sure to install a filter if none was present. There are products made specifically for cleaning between the fins of the condenser and evaporator coils. Use them only as directed.
If these suggestions do not work, you may have a problem with the thermostat, refrigerant level, condenser or condenser fan.
Jun 22, 2011 | Heating & Cooling
Need to replace heater core for Ford Taurus 2000
Heater and Evaporator Core Housing Removal & Installation To Remove:
  1. Recover the refrigerant.
  2. Remove the instrument panel.
  3. Remove the right side cowl vent screen.
  4. Remove the screws and the water shield.
  5. Disconnect the vacuum supply hose.
  6. Clamp off and disconnect the heater hoses at the firewall.
  7. Disconnect the evaporator outlet spring lock coupling. Discard the O-rings.
  8. Remove the two condenser-to-evaporator line bracket bolts.
  9. Disconnect the evaporator inlet spring lock coupling. Discard the O-rings.
  10. Remove the three nuts at the dash panel.
  11. Remove the screws and the heater outlet floor duct.
  12. Remove the evaporator core housing bolt and nut.
  13. Remove the heater and evaporator core housing.
Heater and evaporator core housing removal/installation ford-10-00-404.gif
To Install:
  1. Install the heater and evaporator core housing in the vehicle. Secure the mounting nut and bolt.
  2. Install the heater outlet floor duct. Secure with the mounting screws.
  3. Install the three mounting nuts to the dash panel. Tighten to 53 in-lb (6 Nm).
  4. Install new refrigerant system O-ring seals lubricated in clean mineral oil. Connect the evaporator lines.
  5. Install the two condenser-to-evaporator line bracket bolts. Tighten to 80 in-lb (9 Nm).
  6. Connect the hoses to the heater core connections. Lubricate the coolant hoses with plain water only, if needed.
  7. Connect the vacuum supply hose.
  8. Install the screws and the water shield.
  9. Install the right side cowl vent screen.
  10. Install the instrument panel.
  11. Lubricate the refrigerant system with the correct amount of clean PAG oil.
  12. Evacuate, leak test and charge the A/C system.
  13. Add coolant as needed.
Jan 08, 2011 | 2000 Ford Taurus
How do you replace the evaporator core for the a/c? on a 1994 gmc p/u truck, I've already have the dash out having promblems removing the duct work, what's next? or is there a maunal that will show me.
your instructions are on how to replace the condenser on a 1994 gmc sierra but the title says it is the directions for replacing an evaporator. please correct your title.
Aug 08, 2010 | 1994 GMC Sierra
Evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Where exactly is the orifice tube located at on a 1996 (DOHC v6)?
it's in the high pressure liquid line.
A/C Evaporator Core Orifice The A/C evaporator core orifice (19D990) should be replaced whenever the A/C compressor (19703) is replaced for lack of performance (internal damage). The A/C evaporator core orifice, located in the condenser to evaporator tube (19835), cannot be serviced in detail as a component of the line. If replacement is necessary, follow the procedure outlined for Liquid Line Removal and Installation. An orifice tube replacement service kit may be used as an optional service procedure. Refer to Section 12-00 for information regarding the use of an A/C Evaporator Core Orifice Replacement Kit E5VY-19D695-A.
A/C Evaporator Core Orifice Replacement Kit Installation
  1. Discharge A/C refrigerant system. Refer to System Discharging and Recovery as outlined.
  1. Remove condenser to evaporator tube (19835) from vehicle.
  1. Locate A/C evaporator core orifice (19D990) by three indentations or a circular recess in metal portion of the condenser to evaporator tube.
    A/C Evaporator Core Orifice Location
  1. Note angular position of ends of condenser to evaporator tube so that it can be reassembled in correct position.
  1. Cut a 63.5 mm (2.5 inch) section from condenser to evaporator tube at A/C evaporator core orifice location. Do not cut closer than 25.4 mm (1 inch) from start of a bend in tube.
    A/C Evaporator Core Orifice Section Removed From the Liquid Line
  1. Remove contaminants from the two pieces of the condenser to evaporator tube.
  1. NOTE: The inlet half of the condenser to evaporator tube will be positioned against the A/C evaporator core orifice tabs when correctly assembled.
    Lubricate fitting with clean refrigerant oil and assemble orifice tube kit (with A/C evaporator core orifice installed) to condenser to evaporator tube. Make sure flow direction arrow is pointing toward evaporator end of the condenser to evaporator tube, and taper of each compressor ring is toward compression nut.
    A/C Evaporator Core Orifice Kit Disassembled Components
Jun 05, 2009 | 1996 Mercury Sable
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
43 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
