Back to:
Tags:
Jenn-Air JCD2389G Side by Side Refrigerator
Jenn air Mdl#jcd2389ges Very slow water dispenser (by 4 users)
posted by partouzard on Mar 27, 2008
We get water out of the dispenser but it is so slow that it is not even worth the trouble. Can I check something or replace a part to make it work properly?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by mkx780, posted on Sep 16, 2008
Jcd2389ges Very slow water dispenser problem filter is new but the problem continues what pressure show it have?
jcd2389ges Very slow water dispenser problem have installed new water filter but the problem continues. PLease help or give a idea.
Comment by tsgorg, posted on Jul 20, 2008
same problem - when i depress the water dispenser on inside left of refrigerator, it comes out very slow. I have had this for appliance for about 2 months and slow from the start, is new filter.. HELP!!!
Best Solution
posted on Mar 28, 2008
Helpful (85)
supertechks
Rank:Wiz Wiz
Rating: 92%, 52 votes
You will probably find that if you have a water filter in your model refrigerator that is is clogged. Replace the filter and voila, good flow again. You probably also have small or hollow or chip ice cubes as well, if your filter is clogged.
To save the cost of the filter you would need to check to make sure you are getting strong water flow to the solenoid valve located in the bottom rear of your refrigerator.
I hope I helped, supertechks
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on jenn air Mdl#jcd2389ges Very slow water dispenser:
I don't want to Accept this solution
Solution #2
posted on Jun 30, 2008
Not Rated (0)
polaris6
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a new water line and adequate water pressure, but the water is not cold.
Also, no ice cubes. I suspect that the line is clogged to the ice tray.
How do I clean that line? Is there a filter beyond the upper connection in the rear of the refrig? If so, how do I acces it?
Thanks.
Thank You!
Can you Help with these Refrigerators problems?
My side by side is really hot to the touch between the...
My Jenn Air refrig model # JCD2389GES is not cooling on...
It appears that there is a latch that doesn't catch...
the refridgerator has rotating handles to raise and lower...
my jenn air refrigrator stoped mamikng ice
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
