Question about Shakespeare Surf Fishing Rod and Reel Combo
Where can i get diagram for shakespear sigma series multiplier need to reasemble end part spring has come out thanks
4 Suggested Answers
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
nuworldman
  • 11 Answers
SOURCE: I just recently purchased a shakespear sigma
Baitcast reels are very frustrating to some people. There should be a dial on the side which controls a magnet that keeps it from backlashing make small adjustment and cast also use your thumb to aid in controlling the spool.Then practice practice practice.
Posted on Sep 06, 2009
  • 15 Answers
SOURCE: reasembly of chain brake system
just had the same problem with my husy 357xp all i done was push the kog back onto the handle and pull the handle back to release the brke and fit cover back on with no other problems. If this does not work a pair of pliers or grips and turn the kog by hand this is very hard but can be done hope this helps
Posted on Oct 16, 2009
Do you have a manual on a shakespeare sigma 25 five speed trolling motor
Try Googling (Shakespeare)(25)(manual) without parens.
Jul 12, 2017 | Shakespeare Boating
Ho to tear down Shakespeare Synergy 2000 for a total cleaning
Contact Shakespeare directly to request an assembly diagram.
Apr 17, 2017 | Shakespeare Sport & Outdoor - Others
Shakespeare reel diagrams
You might want to check the numbers you provided. I found this site to have a lot of diagrams for the manufacture you provided. Mikes Reel Repair Schematics
Aug 19, 2014 | Shakespeare Agility Spinning Reel 6825
I have a Shakespear Tiger model TSP50A. I cannot set the on/off so that the handle ends up going both ways. I inspected the gears and suspect a manufacturing defect. I have had it for over 3 years but used...
Remove the spool, you'll find a little screw by a hex nut, remove the little screw then you can remove the hex nut. by removing this nut you will be able to remove the whole bail assembly. There you'll find the workings of the on/off leaver. There is a fine spring that raps around a brass piece that looks like a washer, looking at it from the side you'll see a grove in it, that is where the spring goes then to the leaver of the on/off control. This spring hardly has any spring to it so don't think it needs a replacement. If the spring is in place check to be sure that the knob isn't striped. Just take the little screw off that holds it in place and inspect it. I hope this helps!
Jun 17, 2010 | Shakespeare Agility Spinning Reels
Parts diagram for sigma faucet
http://www.sigmafaucet.com/media/cms/specifications/400408.pdf
I found this series on line at the link above the only number off one number off. Check out the link below for all sigma faucets. I hope this will be helpful for you.
http://www.sigmafaucet.com/ecommerce/prod_details.asp?pid=1408470&img=&cid=816144586725
Jun 14, 2010 | Home
Problem with anti-reverse
if it is a multiplier reel most of the lever tension springs are the same. they can be bought from QUENTIN MILLMAN in portsmouth. they have a mail order branch and can be located on line.i have tried making my own springs but the dog leg has to be at the right angle.best buy the right one for a few pounds. regards barry.
Sep 21, 2009 | Sport & Outdoor - Others
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
A code for 27inch 700 wheels for sigma bicycle computer needed
Dear spinnerrr
  • Multiply the wheel diameter in mm or cm by 3.14.
  • Measure the distance travelled in one complete turn of the wheel.
this is the four digit number you are looking, it should be between 2145 and 2149
Regards
Mar 21, 2008 | Computers & Internet
Shakespeare Surf Fishing Rod and Reel Combo Logo
79 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
