Question about Hotpoint First Edition FEW10P Front Load Washer
Fixing new brushes - Hotpoint First Edition FEW10P Front Load Washer
  • bates747 Mar 27, 2008
    i want to fix new brushes i opened the top of the washing machine how do i get into the motor to get the brushes out as i dont know how to get access to the motor
  • Hotpoint Master
  • 3,463 Answers
To fit new brushes to Hotpopint, you need to remove the rear panel if the washer.
There you will see the motor. remove the motor and fit the new brushes
Posted on Dec 01, 2008
6ya staff
SOURCE:
I have a spin brush Conair infiniti pro and the brush stopped spinning. How do I fix it?
Replace the brush bar you'll have new brush bar better clean than old brush with new bearing which aren't available or worth the bother fitting, ps keep the filters clean makes a real difference to sucking power.
Oct 22, 2017 | Conair Vacuums
Bosch wfl 1880
spin switch will fix this
Dec 16, 2013 | Washing Machines
Turbine Head Brush Tool - Noisy
See if there is something wrapped around the brush area itself which could cause the noise
Jun 06, 2012 | Dyson Vacuums
Brokenwire on a gen brush, can' find a new on local, what can do to fix this one?
Might have to make a calculated work to mend the wire with a lead so as to be fixed back to the brush.
use of a good soldering iron with good wattage to remove old lead and fix the new one.
Sep 24, 2010 | 1979 Yamaha XS 650 F
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
I have a Proheat 2X. The tough stain brush adhesive has separated from the plastic. How can I fix this or do I have to order a new brush?
Check brush belt and cleaning all......brush no brokner if you need replaced
Part no: 2036686
Brush - 6 Row (1) w/Swivel Arms
Nov 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Hotpoint First Edition FEW10P Front Load Washer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
