Question about Hotpoint NVL333EY Electric Dryer
Dryer continues to run with door open - Hotpoint NVL333EY Electric Dryer
    President:
  • 2,468 Answers
You need to replace the door switch,sometimes you can do this without removing the front panel,unplug the dryer and with a flat blade like a putty knife get behind the switch body and pry it out being careful not to scratch the paint,mark the wires on the switch and get a replacement
Posted on May 09, 2010
Plugged in my Sonya apartment sized dryer and turned it on, it does not run at all. Is this a fuse problem? Please advise.
First make sure you are getting power to the outlet. Second thing to check is the door switch and the thermal fuse. Use an ohm meter and check for continuity through both switches. The door switch should have continuity when the door is closed and no continuity when the door is open. The thermal fuse should have continuity all the time.
Jan 15, 2017 | Dryers
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Lg dryer wont turn off
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
Nov 03, 2012 | Dryers
Not turnining on got power everywhere, but am I supossed to have continuity every where on the door switch.
  1. the door switch is a 2 part switch,as in when the door is open and the light is on 2 of the 3 terminals will have continuity,when the door is closed the other 2 of the 3 terminals will have continuity so as for the dryer to start and run,there is 1 of these terminals that is common to the other 2 terminals so between that common terminal and either of the other 2 terminals depending where the switch is positioned there will be continuity and the other will be open,then when you change switch position then the open terminal will have continuity and the opposite terminal will be open circuited
Mar 08, 2011 | Maytag MED5600TQ Electric Dryer
I have model #110.76712645 The dryer does not
open the door and push on the door switch paddle,if it doesn't click the door switch is broken.when you open the dryer door while it's running the dryer should shut off,if the switch breaks the dryer will either not run or will stay running,if the switch is clicking and is good then you have a broken push to start switch.this is the button you push on to start the dryer,this could break in the on position.let me know what you find
Jul 14, 2010 | Kenmore Dryers
Dryer will not shut off dryer will not shut off
door lock or door micro switch
Nov 29, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
114 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
