Hi and welcome to Fixya, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Testimonial: "Great suggestion. I had checked the circuit with a tester and found that I power, but after your note I dug a little deeper and found the white wire had deteriorated inside the twist nut and was not making continuity. Works great now. Thanks again"
I had this exact same problem. When I took off the cover however I found that the neutral wire for my dishwasher had gotten so hot that the insulation had smoldered off of it and what copper remained what completely brittle. The inside of the cover was scorched too.
Activate the trip reset button.
Does the odometer display switch between trip and odometer?
Does the scan tool communicate with the control modules listed above?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Important: Program the replacement instrument panel cluster (IPC).
Replace the IPC. Refer to Instrument Cluster Replacement .
Did you complete the replacement?
Go to Step 4
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Install a scan tool.
Does the scan tool power up?
Go to Step 2
Go to Scan Tool Does Not Power Up in Data Link Communications
Body Control Module (BCM)
Driver Door Module (DDM)
Electronic Brake Traction Control Module (EBTCM)
Inflatable Restraint Diagnostic Module (SDM)
Instrument Panel Cluster (IPC)
Liftgate Module (LGM)
Passenger Door Module (PDM)
Powertrain Control Module (PCM)
Go to Step 3
Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
