Question about Dell Dimension 4600 PC Desktop
I'm having a problem pluging in my speakers and getting a sound.
I've tried to get my speakers to work, but so far no luck.
    Problem Solver:
  • 10 Answers
Look for the little circle pluggin thats green
Posted on May 09, 2010
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | Computers & Internet
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
I have my speakers pluged in probily but the sound isn't working
chek the power suply connection 9light on)
chek the vol on the speakers
chek the vol on the computer
try to connect them on another computer that have other speakers that are working
bernard
http://www.rylwy.com/
Feb 10, 2012 | Dell A215 Computer Speakers
I purchased a set of Logitech LS21 speekers and I can' get them to work. Below is a list of my system hardware and the steps I have done so far. Motherboard is a Gigabyte GA-MA785GM-US2H 16GB RAM AMD...
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
Mar 07, 2011 | Logitech LS-21 2.1 Speakers
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
No sound from speakers
Did you try reinstalling the sound card drivers?
May 10, 2008 | Microsoft Windows XP Home Edition
HEADPHONE SPEAKER WIRING
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Apr 05, 2008 | Hitachi DZ-MV730A DVD Camcorder
Speaker doesnt give sound
Based on the fact that you have put a headset in and another speaker system and it is working properly there is nothing wrong with your windows settings. I would leave them alone. The issue appears to be with the hardware. Have you attempted to plug the speakers into another source (ie. cd player, ipod, etc)? If you plug them in there and they don't work, take the speakers back and have them exchanged. If they're not under warranty you're going to have to either get them fixed or replace them. Good luck on this one! JC
Sep 30, 2006 | HP P5302M Computer Speakers
Dell Dimension 4600 PC Desktop Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
