Question about Haier HWR10XCA Air Conditioner
How to remove plastic front to clean
I found one screw inside but no others, front won't come off to clean unit? preference plus series hwr 10xc3
  • Ken Bledsoe May 11, 2010
    It is a press fit. need fan puller
  • Haier Master
  • 4,654 Answers
I will tell you that every brand has a different way of removing the front face cover. I sell the Haier Central Heat Pumps and Air Condioners and repair window units. Click Here for the user guide=> HWR10XCA
Most fronts come off after pulling the front cover facing from the top as the bottom is sitting into clips. Most are but you removed a screw fromsomewhere and it just may be only one tha keeps it snug so the cover will remain firm. Here is a link to=> Haier America and thier contact link=> Contact Us and their=> Hot Line
AMERICA & AUSTRALIA U.S.A. & Canada All Haier Products
Hotline : 1-877-337-3639 Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on May 10, 2010
Managemylife
there are screws on the inside they go thru the drum, you would need to open the front of the dryer, to access them.
Aug 28, 2014 | Kenmore Dryers
How to remove the screen from the y510
The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
Goes by many names. Display Bezel is used by HP.
Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
Lenovo/IBM uses LCD Front Bezel.
Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
(Hardware Maintenance Manual)
http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
(An HMM is a Service Manual)
I also see there are no guides posted by users.
Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
1) Do you see any screw covers on the LCD Front Bezel?
May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
Example,
http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
Scroll down to the photos in Steps 1 and 2.
Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
We'll start with this.
2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
{ ALL power removed before beginning. Remove the AC adapter
(Charger), and Battery }
3)
A) There is no sticky double-sided tape holding it on.
B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
[ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
When the Display Bezel is removed, the locks snap loose ]
C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
This is what I mean by pop off,
http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
Step 2 and 3.
{ The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
Post back in a Comment.
Regards,
joecoolvette
May 06, 2012 | Lenovo IdeaPad Y510 Notebook
Kenmore washer mod#11044936200 error code f02 also makesloudnoise like a grinding
The reason for F02 error is due to something stuck inside the drain pump. Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover, pull the cover off then remove the strainer. It will have gray **** on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on.
Sep 20, 2011 | Washing Machines
I am 99% sure I have a bad fan. TV was turning off (probably overheating). We replaced the lamp (for the fourth time), but the fan continues loudly when the set is turned on. Question-- Can I replace...
Tools/Supplies:
• Phillips screwdriver (magnetic tip)
• 1/4" nut driver
• 1/4" wrench, small adjustable wrench, or stubby Phillips (to access screw in tight spot)
• Canned air with extender tube, a few cans
• Optical-quality microfiber cloth
• Clean, lint-free cloth
• Small brush
Precautions:
• Do not use any cleaner that contains ammonia. A clean lint-free cloth dampened with water was adequate for me.
• To prevent over spray, do not spray any cleaner directly on to any TV part. Spray on to rag only. (I only used a dampened rag to clean plastic and metal surfaces; no electronics or optical surfaces.)
• Use only an optical quality microfiber cloth and/or canned air to clean the light engine lens, the mirror and the inside surfaces of the front screen.
• Exercise caution using canned air. Do not tilt the can and allow any liquid propellant to escape. I had a few full cans available, and swapped to a new can often.
• Keep screws removed from each panel in a different cup. Most are different sizes.
• When disconnecting wiring connectors, note color codes for connector orientation when reconnecting. Most connectors only install in one orientation, but it's not clearly obvious.
• If contacting any circuit boards/wiring connectors, make sure to touch the metal frame first to discharge any static charge.
Disassembly Instructions:
1. Insure TV is powered off and allowed to cool at least 2 hours (overnight if possible).
2. Open and remove the Lamp Unit door on left side of TV. Using a Phillips screwdriver, loosen the 2 screws on the lamp unit and carefully remove the lamp unit.
Clean lamp unit, using microfiber cloth on the lens and set aside for reinstallation.
3. With the lamp unit removed, you can see the light engine's color wheel through the small hole. I covered this hole with tape to prevent any dust from entering during my cleaning.
4. Remove the lower rear cover (2 screws on each end and 9 along the back panel).
5. Remove the cover from the Input/Output jacks by removing the 7 silver screws securing the cover to the Input/Output modules and sliding the cover off the power cord grommet.
6. Remove the front pedestal cover as follows:
Note the blue, red and grey wire harnesses on the right side leading to the front panel controls, AV-3 jacks and PC slots. Loosen and remove these wires from their wire ties.Grasp the pedestal cover at the ends and gently pull outward. It is installed with quick-release pins and should release easily.Gently pull the pedestal cover out, being careful to guide the wiring.Carefully disconnect the 3 wiring connectors, noting the color code for reconnection.In preparation of removing the front screen, 2 hidden screws must be removed. These 2 screws secure the bottom corners of the front screen and are installed from the back.
7. Remove the plastic housing where the lamp unit was removed:
Loosen the wire tie and remove the wires from the top of the plastic housing (these wires go to the lamp door switch).Remove 2 screws securing plastic housing. One on left side and other in base on right side (with limited space available, will need 1/4" wrench or stubby Phillips).Slowly pull housing from TV, until you can reach the connector to the lamp door switch. Note color code and disconnect wiring connector (may be easier to pull some wire through the hole and lift upward to remove connector).The front panel screw can now be seen in a recessed hole. Loosen this screw. (I did not remove the screw completely, to aid in reinstallation. Otherwise, a magnetic Phillips screwdriver may be needed.)8. From the area of the front panel wiring ties the other hidden front panel screw can be seen in a recessed hole. Loosen this screw.
9. Remove 11 of the 12 screws along the back of the TV securing the front screen, leaving one loosely installed at the top.
10. Remove 4 of the 5 screws on the front of the TV, at the bottom of the screen.
11. While holding the screen at the top and bottom, remove the two remaining screws, and gently lift and pull the front screen panel away from the TV.
Store the front screen assembly where the inside surfaces can be cleaned with the microfiber cloth and/or canned air.
12. Reassemble the TV in the reverse order, remembering to remove the tape from the hole covering color wheel, if installed earlier in step 3.
There are 3 fans to clean:
The large Lamp Fan behind the lamp and light engine assemblies is clearly visible.There are two smaller fans mounted next to each other. One fan is mounted between the cable card slot and the light engine and the other fan is mounted just to the right directly on the light engine assembly. It's somewhat inaccessible without removing the light engine, but using an extender tube on your canned air, it is easily cleaned.
The lens of the light engine will have the most dust. Clean with canned air and the microfiber cloth. Use a corner of the cloth to reach beneath the plastic tabs covering the lens.
The mirror may have a few dust particles. Gently wipe with the microfiber cloth and use canned air. Hope this helps,
TechGuy21
Jul 04, 2011 | Toshiba 62HM95 62" HDTV
Wash load stops with a few minutes left and unit alarms f02, don't see any visable drain problems
Hi, pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error code
The reason for F02 error is due to something stuck inside. Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business
Thanks for contacting Fixya.
Nov 03, 2009 | Kenmore Elite 45986 Front Load Washer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
Cleaning inside the fan
Unplug the unit from the wall for safety. Remove the two screws in the upper hand grip recess (upper back of the unit). The two screws must be completely removed (not just loose and setting in the holes). Once the two screws are out, the back half of the fan cover can be slid downward (some amount of force is needed to unsnap the two halves from each other but be careful since the parts are all plastic and can possibly snap). Once the back is unsnapped from the front, you can lift the back half away from the front half and the inside parts are now accessible. I have found on my fan that it is the top fan shaft / bushing that is causing the squeaking noise that so many have complained about. I have found that periodically lubricating the top shaft/bushing will make the fan sound like new again - for a while. Every 2 - 3 weeks I need to clean (wipe off old lube) and re-apply fresh lube).
Jul 19, 2008 | Bionaire BT45RC Tower Fan
Leaking water out of front vent when opened
Hi jpkenney, The vent can be replaced. If you open the door and look around the outside of the door, you will see the stainless screws that hold the top & bottom parts of the door on.( the top control section is separate to the rest of the door). Just undo the screws & there you have it. The vent can be replaced easily. Hope this helps.....goodluck.
Jul 29, 2007 | Miele 24 in. G881SCI Built-in Dishwasher
Haier HWR10XCA Air Conditioner Logo
440 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
