Question about Dell Inspiron™ E1505 PC Notebook
Cursor stops working when power cord is plugged in...
If I'm operating the notebook and it's not plugged in (running off battery power), then I have no issues with my cursor.
If I plug in the notebook to recharge the battery, the cursor is almost useless. It'll jump over page, click constantly without me hitting the button, and eventually just freeze up. It can be completely locked and as soon as I unplug the power cord from the computer, everything works fine again.
Thoughts?
  • bigmarc27 Mar 30, 2008
    I tried updating the drivers - no luck on that. I'm working on options #2 and #3 to see if it works.
    Thanks.
    Problem Solver:
  • 13 Answers
It sounds as if the power coming through your ac adapter may be causing interference with the touchpad, meaning perhaps an electrical signal is crossing into your mouse or disrupting its signals.
You could try to download the latest drivers for your touchpad and see if that fixes the issue.
You should also (if you haven't already) try a different mouse to see if the issue is related to the mouse sub system, or the touchpad itself.
If possible, try a different AC Adapter to see if that may be the issue.
Posted on Mar 27, 2008
Zv6000 will not charge will not run off of cord
Try another Cord/Charger with the EXACT same power specs. Has the AC jack been damaged due to pulling on the cord while plugged in?
Apr 13, 2013 | HP Pavillion ZV6000 Notebook
Laptop will not start on battery
Is the battery charging? What does the battery icon say when you hold the cursor on it? How old is the battery? Is it original or a replacement?
Mar 08, 2013 | NEC Versa VX Notebook
Why is my notebook not charging during use
The issue would be in one of two places. 1) The power cord may be faulty. 2) The power jack on the laptop has stopped working. Fortunately, both of these can be replaced. Check the power cord for damage to the insulation, if any is found it needs to be replaced. If there is a "power" indicator light on the power pack, make sure it is lit. If not, it needs replaced. If a visual inspection of the cord checks okay, plug it in to the laptop and check for movement on the jack. If there is no movement, check to see if the "Plugged in/Charging" light is illuminated. If not, the power jack is faulty. I hope this helps you.
Feb 16, 2013 | Acer Aspire One PC Notebook
My notebook is not turning on,how do i know if its the battery
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | ASUS Computers & Internet
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Touch pad isstP Pavilion cursor starts drifting uncontrollably
try removing your battery and replace it back. its like resetting it.
May 16, 2009 | HP Pavilion dv4000 Notebook
HP dv9005us will not start. The computer was running , then lost the cursor. Had to control-alt-delete to resart. now will not restart. The working lights come on; click a few times; then operating lights...
okay in this case you have to take the battery out and power cord also not connected to the laptop . and then hold down the power button for 2 minutes and then put the battery in the machine and then try to boot the machine .
so that will work . if that still didnt work then boot the machine in the safe mode and then do the system restore to the erlier date .
START- PROGRAM - ACCESORIES - SYSTEM TOOLS - SYSTEM RESTORE
Mar 27, 2009 | HP Pavilion dv9005us Notebook
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
Dell Inspiron™ E1505 PC Notebook Logo
407 people viewed this question
Alun Cox
