Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Water leaking out of door , seems like it might be a problem with the door hinge ?
  • 1,543 Answers
Not likely that you have a hinge problem, but it can happen, especially if water has been dribbling down the back side of the front panel from the dispenser area, getting on the hinge, and causing it to bind up. Replacing the hinge is a pain because the screws are put in with thread lock, requiring heating or even drilling in some cases. If you have water dripping down the front of the machine from the door, the most common reason is that there is some lint or hair on the bottom side of the glass door, preventing a complete seal to the gray rubber gasket. Generally, just cleaning off the bottom of the glass door will fix it. If that does not do it, you can try moving the spring clamp (which holds the front of the gray tub seal) from the bottom (6 O'clock position) to the hinge area (9 O'clock position) Sometimes, the leak is caused because someone pushed the washer into place by placing their hands just below the door and actually deformed the metal front panel inward, preventing a seal between the door glass and the gray tub seal. If that is the case, it may be corrected by removing the spring retaining clamp, taking the front of the gray tub seal off, pulling outward a bit on the metal panel at the bottom of the door openings, and replacing the seal and retaining band again.
Posted on May 09, 2010
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • Jul 25, 2011 | Refrigerators
    Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
    Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
    PSS service manual
    Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Maytag MFI2569VEB1 french door refrigerator has started leaking water from underneath. Seems to be coming from the left (facing) side, near the front. I checked water connection in back and in the left...
    I will look for your service manual and tell you that first it's most likely a blockage in the defrost condensate line. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan,
    water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage.
    Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
    Dec 17, 2009 | Refrigerators
    Front loader washer leaks from bottom center of door osmetimes
    Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
    Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
    Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Water leaks on the floor near the door hinge
    This is commonly caused by a worn door seal. Post your make and model number and I can assist you in identifying a part number.
    Apr 29, 2009 | Dishwashers
    Our fridge door won't close properly
    The door hinges have nylon bushings/washers to help them work smoothly. If the unit is very old and had a lot of use (like a large family) the bushings or washers could be just worn away. This also is indicated if the doors seem to be misaligned. If the doors don't seem out of place, it could just be that the unit is not sitting on a level surface, causing the box to twist and the doors th therefore bind.
    Other possibilities: The door is burdened heavily with the milk, juices, food, etc. and therefore is just plain heavy. You have a "water-thru-the-door" unit and some leak has occurred to fill the door and it's insulation with water. (eww!)
    Check to see that the surface is level, and that the door fits correctly. Make replacements or adjustments as necessary. Lighten the load on the door, or fix the leak.
    If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
    Dec 18, 2008 | Kenmore Refrigerators
    Washing Machines Logo
    300 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
