Question about RIM Blackberry Curve 8520
How do I pair blkberry 8530 w/ bmw bluetooth bmw 325
  • Anonymous Mar 22, 2014
    How do I get my blkberry bold to pair with my ihome idm speaker? Pls help!
  • 219 Answers
Check out www.wireless4bmw.com
Posted on May 27, 2010
Can't pair iPhone on 2005 BMW x5
did you mean via bluetooth? if yes please remove saved car kit devices from you phone and then try again with correct pass-codes
Sep 09, 2014 | Apple iPhone Smartphone
Bluetooth pairing. Audio works but contacts not transferred to car. Samsung Galaxy S3 says "audio only"
Having same problem. Same galaxy 3 Phone not compatible with my
BMW system bluetooth either.
May 04, 2014 | 2006 BMW 5 Series
Bluetooth Samsung Galaxy s3
Turn on bluetooth on phone.
- settings-bluetooth > on
Turn on bluetooth in car stereo
- Turn on radio, press Menu.- Scroll with knob to Phone. - Press knob to Select.- Turn knob to select Pair.
Back to Phone
- Hit the Scan button to search for BMW bluetooth- Find BMW Bluetooth name on phone and select Pair. - If should ask for a passcode, enter identical pass codes on stereo and phone.
Nov 05, 2012 | 2006 BMW 5 Series
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
Use your Bluetooth Headset with your Blackberry
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
My Blackberry 8530 is not pairing correctly with BMW
It took me days to find the problem. I have a new Curve 2 and a 2007 335xi without Idrive. My old curve worked perfectly.
I dug into the settings and found that the default on the Curve 2 was "Encrypted". I turned it off and that was then instant end of the problems. Oddly, my old Curve was set to "Encryption" for all three BMWs it had on its' list.
Regardless, it worked.
May 01, 2010 | RIM Blackberry Curve 8520
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Apr 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I want to connect my Blue tooth device to my BlackBerry 8530 and I don't know how- This Bluetooth device used to be connected to a cellphone I had over a year ago- Now I have the NEW BlackBerry 8530... but...
In order to pair this headset with your BlackBerry, you need to place the headset in to pairing mode. To do this, press and hold the talk button until the indicator light turns blue and stays lit after blinking.
After you do this, go to the bluetooth setup area and search for a device. Once it locates your headset, it will prompt you for a PIN. This PIN should be the factory default, 0000. I hope this helps!
Mar 21, 2010 | Samsung WEP650 Bluetooth Headset
How do you connect mobile phone to in car handsfree on a 2003 bmw 320ci se convertaible
To do that ignition off, press and hold the bluetooth pairing button located to center console for 3 sec. switch to ignition key to 1st position(acc) and keep press holding the button for another 3 sec untill the bluetooth pairing sign on then you can start bluetooth and mobile pairing
Nov 23, 2009 | 2003 BMW 330
RIM Blackberry Curve 8520 Logo
222 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
