Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I have a frigidaire gallery stackable washer dryer unit model #GLET1041AS1. The dryer gets hot but takes a long time to dry. Is there a fan or blower in the unit that is supposed to circulate the heat and maybe this blower isn't working?
4 Suggested Answers
ezed51
  • 7 Answers
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Posted on Jun 01, 2008
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
  • 38 Answers
SOURCE: Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Posted on Oct 04, 2009
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
Dryer hot but not drying quickly.
Sounds like you have a clogged vent. Hopefully you've gotten this repaired.
Feb 25, 2012 | Frigidaire Washing Machines
Frigidaire stackable washer and dryer...model # GLET1031CSO was drying clothes, opened dryer to check, will not come back on. Washer still wroking fine. Can you help me? I checked breaker, it is fine....
Sorry to read about your problem, I hope this helps you out.
You may have a defective door switch, or lost a control board.....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Frigidaire Washing Machines
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire dryer problem
The vent duct length's sound fine.
Have you confirmed that the heater element is working? You don't mention whether the unit get's hot.
If it get's hot, then suspect the thermostat, or the overtemp stat.
Also, be suspect that users are overloading the dryer.
Also make sure that you feel a strong blast of hot air discharging at the vent end, with the washer/dryer in place.
Check that the vent grills inside of the dryer are clear.
Reply back and I can help you further.
Feb 03, 2009 | Frigidaire Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
247 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
