Question about Acer AL1916W 19" LCD Monitor
AL1916W (6 years old) "Auto Config Please Wait" wont go away. Menu doesn't respond. Left and right arrows dont respond. Same on another computer.
  • 4 more comments
  • David Stacey May 09, 2010
    I already did that. Originally it had a generic Microsoft driver dated 2001.
    I have installed the latest driver from Acer dated 2005.
    As I have already said-I have already installed an updated driver.
    I find this hard to believe. I am using XP Home. A new video card Nvidia GE Force 9800 GT. My display wont go that high. I have it on the highest rating of 72 htz refresh rate allowed, although I note the Acer specs say it can go to 85!
    In addition to previous reply to you, I should mention that the screen moves from side to side. When I press and hold the left or right button the message goes away.
  • David Stacey May 10, 2010
    Is it possible it cannot be fixed because no one knows
    whats wrong?
    What is the PCB?
    Guru:
  • 825 Answers
The PCB present in the front side of monitor is gone... open the screws from behind, and remove the front panel... Take the pcb along with the switch present in it... check for any physical damages.... if no then clean it with thinner or petrol using a old tooth brush... plug it back and connect all necessary wires... Now check by turning on.... still same problem then you need to replace that part alone with a new one... no other go....
You can also remove that entire unit and work with the computer,but you wont be able to adjust the settings in the monitor....
Posted on May 10, 2010
  • Manikandan Raj May 10, 2010
    A printed circuit board.... PCB
  • 83bj60 Nov 14, 2011
    EXACTLY the right answer for this issue. To take the front bezel part easily use a stainless steel ruler between the two halves and twist, it causes the least amount of damage. Disconnect the cable from the button PCB and the problem is solved.
    Not having the menu controls has no effect in real life. If the picture is wrong disconnect the power cable; upon reconnecting it will go into autoconfig (once) and get the picture right.
    President:
  • 1,851 Answers
I'm suspect about the situation of the buttons. Have you checked if the "auto" button has been loced in press potition? By the way what is the resolution you use on that monitor? (1440 x 900 is the Native Resolution)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 09, 2010
    President:
  • 1,070 Answers
Dear Friend,
Go to This Site Click and follow
It seems to be Driver Problem...Update your Driver...
Hope this make you better..Thanks for Contacting FixYa...
  • 1 more comment
  • shafi
    shafi May 10, 2010
    Hello Friend,'
    Click on MENU...Go to Horizontal/Vertical Adjustment > Manually adjust it(Move left & right for Horizontal and Move Up & down for Vertical Adjustment)+Adjust Focus Focus of the Image......
    ...Still Have Problem
    Have you tried Restore factory Settings
    This is automatically adjusting your Window[Auto Config Please Wait].If you don't have Complete key Instruction then Click here for the rest of setup......
    Hope this helped you................
  • shafi
    shafi May 10, 2010
    Sorry,I wasn't here when you posting above Comments ..That was made late to answer for Comments..
  • shafi
    shafi May 10, 2010
    If Menu Key is Not Working /not Responding properly for any Attempt,then it may needs to manual repair ...
How would you reset the fuser life for Dell 5330dn printer?
power on the printer
Wait for ready mode.
Press Menu -> Up -> Left -> Ok -> Right ->Cancel ->Menu
This will bring you the the Tech Menu, select it.
navigate to Data Setup (Down arrow) and press check
navigate to Clear Fuser Count and press check
Power on and off
Print a config from the reports menu to check if the fuser count 0.
keep in mind you have to press the keys (for getting tech menu) really quick, try not to look the display but the keys (the menu, up, left, ok, right, cancel, menu combination i mean)
good luck
Sep 20, 2011 | Dell 5330dn Laser Printer
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 | Cameras
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
HOW TO ADJUST THE BRIGHTNESS AND SO ON.
Press the OSD button to show the On Screen Display.
Press the UP/DOWN or LEFT/RIGHT buttons to move through the various menu-items.
When you get to the correct item, press OK to select that item.
Then, use UP/DOWN or LEFT/RIGHT buttons to adjust.
Press OK to "accept" the adjustments.
Wait a few seconds, and the OSD will vanish.
Jul 30, 2010 | Acer AL1916W 19" LCD Monitor
Change the time on DV 1130
Manual Clock Set
1 Press MENU to display the MAIN menu.
2 Use up/down arrors to choose the CLOCK menu.
Press ENTER and the CLOCK menu will appear.
3 Use left/right arrors to choose the MONTH option.
4 Use down arrow to choose the DAY option.
Use
L/R arrors to choose the date.
The day of the week will display automatically.
5 Use down arror to choose the YEAR option.
Use
L/R arrow to choose the year.
6 Use down arror to choose the TIME option.
Use L/R arrow
to choose the time.
Press and hold L or R arrow
to advance the clock
continuously.
7 Use down arrow to choose the DAYLIGHT SAVINGS
option.
Use L
or R arrow to choose AUTO, ON, or OFF.
If you choose AUTO, the VCR sets the clock using the
DST information broadcast in the signal (channel).
If you choose ON, the VCR adjusts the clock for Daylight
Saving Time automatically.
Mar 23, 2009 | GoVideo DV1130 DVD Player/VCR
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Auto Config Please Wait message
Each monitor has a menu option. Find out with your manual how to access your menu options for your specific model and in there is an option to display messages or warnings. You can turn it off there.
Dec 01, 2008 | Acer Computers & Internet
Config problem
Have you tried using the monitors menu to move the screen manually. Exit, then turn the monitor off. When you turn it back on the picture should be where you left it.
Sep 14, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
