Question about Fujitsu Siemens LifeBook® S7110 PC Notebook
Laptop Not booting up, Scroll Lock indicator blinking
Fujitsu Lifebook s7110 Laptop froze while working.
Restarted using Power Off key
No longer booting up after that - Screen Blank
Tried reseating the RAM - no effect
Tried booting without battery - no effect
  • jferrao May 10, 2010
    The interpretation is a Memory problem.
    Tried removing and reseating the RAM - but the problem persists
    Tried with a new RAM - but the problem persists
  • 44 Answers
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
Posted on May 09, 2010
  • Agnaem May 11, 2010
    Suppose that the user guide is dependable, then the RAM slot itself may be faulty.
Lifebook s7110
Put the start op disc in the drive restart your laptop and follow he prompts
Sep 30, 2013 | Fujitsu Siemens LifeBook® S7110 PC...
Futitsu Lifebook not booting - first screen only.
What you would need to do is go to the power button, turn on and immediately hit the F8 key and go into safe mode with networking, and then run malware bytes to see if there is any virus's on the computer, use this link to download malware bytes free edition to clean the computer of virus http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Once completed, then if it still doesn't work, you would need to reload the operating system, make sure the computer is backed up, then use the install disks that came with the computer when you bought it, the install will take about 2 hours, if you don't have the install discs call the manufactuer and then will send you them in the mail for free to reload the computer software.
Jul 28, 2013 | Fujitsu Siemens LifeBook® S7110 PC...
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Fujitsu siemens s7110 laptop bios password
if youve forgotten the bios password you will need to remove the main battery, the power cord and disconnect the cmos battery to clear the bios password
its better to have a tech do this for you
Dec 07, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
My fujitsu laptop s7110 i cannt enter bios its asking password .how can remove this plz give me a solution
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 01, 2010 | Fujitsu Siemens LifeBook S7110 Notebook
3 others indicators start blinking !
Dear friend,
Just follow the instruction.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and enter.
Then just wait and watch what's is going. If the same problem then contact me again here in Fixya i will give you another way to solve the problem. Thanks.
Feb 03, 2010 | Fujitsu Siemens LifeBook S7020D Notebook
My Fujitsu-Siemens Lifebook S7110 display going black time to time. It's coming back after restarting and it's working great with external monitor.
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
Dec 20, 2009 | Fujitsu Siemens LifeBook S7110 Notebook
I may be totally retarded but I have no clue what the padlock with two arrows in it. It is on top of my keyboard next to the lighted indicators for num lock and shift lock.... anyone have any idea what...
The scroll lock key was meant to lock all scrolling techniques, though it is no longer used by almost any software. In the original design, scroll lock was intended to modify the behavior of the arrow keys. When the scroll lock mode was on, the arrow keys would scroll the contents of a text window instead of moving the cursor. In this usage, scroll lock is a modifier key like ALT and SHIFT (which modify the function of other keys) and, more specifically, a toggling Lock key like NUM lock or CAPS lock, which have a state that persists after the key is released.
Regards;
Hassan
Jul 22, 2009 | Fujitsu LifeBook N7010 4GB 320GB HDD PC...
Fujitsu Siemens LifeBook® S7110 PC Notebook Logo
3,752 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
