Question about Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards
We have a mercury 60 2stroke outboard engine and nothing happens when you turn the key to start it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
Posted on Aug 23, 2010
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
Pull cords broke and cant get her to turn over
remove the recoil unit and under there you will see a groove on top of the flywheel where you put a rope to emergency start ! fix recoil after you know engine ok !
Apr 10, 2014 | Clymer Mercury 3.5-40 HP Outboards...
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Mercury outboard
Sounds Like You Have An Ignition Switch Problem,
Disconnect Yellow/Red Wire From Starter Solenoid In The Engine,
Turn Key On Does It Try To Start Y/N
If Yes Then Starter Solenoid Is At Fault /Replace It!
Good Luck
Apr 02, 2013 | Light Outboard Motor Boat Bass Fishing...
Mercury Outboard 25 HP 1993 Model
If it would not move (rotate) you had a pump failure. A bad pump will often pump enough to go fast but nothing at idle so will quickly sieze.
Aug 17, 2012 | Boating
Engine turns but wont start
check the key that year modle has a chip in the key and if it was around something magnetic it could have lost it's programing. If that is not it the there is a fuel rail with what looks like a air pressure valve. turn the key on and press that valve if fuel sprays out it is your key. If fuel doesn't spray the it is your pump
Feb 07, 2009 | 2002 Mercury Mountaineer
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Logo
407 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
