Question about Toshiba Satellite A135-S2276 Notebook
System is on but there is no display - Toshiba Satellite A135-S2276 Notebook
  • 74 Answers
No display can cause by many thing. RAM, LCD, motherboard or any thing connected to motherboard. So, if you have knowledge in this field, you can : - try to take out and put the RAM back to the slot OR you can try with other RAM. If this solve the problem, your RAM problem
Second, you can try plug in VGA cable (connected to external LCD monitor) to the VGA port on the notebook. This step is to check either your notebook can enter windows or not. If the display come out at LCD monitor, means your LCD @ LCD cable problem.
If those thing cannot solve the problem, means either your motherboard or VGA card (for notebook that come with VGA card) problem.
Solution : Send it to service center @ any computer shop
Posted on May 09, 2010
Coil not reset odo after oil change please let me know how I can reset
1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3
i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1)
i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and
-, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3)
i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3)
i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and
-buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and
-, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i
If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3)
i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
Copyright
Jun 22, 2012 | 2006 Mercedes-Benz R-Class
Howdo i enter diagnostic mode 1994 deville
TROUBLE CODE DISPLAY:
After entering On-Board Diagnostics, a segment check is automatically performed and then any trouble code stored in computer memory will be displayed. Codes may be stored for the Powertrain Control Module (PCM), Instrument Panel Cluster (IPC), Air Conditioning Programmer (ACP), Supplemental Inflatable Restraint (SIR), Traction Control System (TCS) or Road Sensing Suspension (RSS) systems.
Each trouble code consists of the system abbreviation: (E: Engine, PCM), (I: IPC), (A: ACP), (R: SIR), (T: TCS), (S: RSS), a three digit code identifier, and the letter C or H. All codes for each system are displayed together, in the order of their three digit number (lowest first). The final digit of the code, a "C" or "H" is used to indicate whether the code is Current or History. A "C" means the fault was still present the last time the diagnostic test was run, while "H" means the failure was not present the last time the code was tested for.
If no codes are present for a system, a "NO X CODE" message (with "X" being the system i.e. E, I, A, R, T or S) will be displayed. If the communication line to a component is not operating, a "NO X DATA" message will be displayed, indicating that the IPC could not communicate with that system.
SELECTING THE SYSTEM:
After trouble codes have been displayed, a specific vehicle system PCM, IPC, ACP, SIR, TCS, RSS may be selected for testing.
The first available system will be automatically displayed (i.e. PCM?). While selecting the system to test, any of the following actions may be taken:
  1. Depressing the "HI" button on the CCC will select the displayed system for testing.
  2. Depressing the "LO" button on the CCC will display the next available system selection. This allows the display to be stepped through all system choices. This list of systems can be repeated following the end of the system list.
  3. Depressing the "OFF" button the CCC will stop the system selection process and return the display to the beginning of the trouble code sequence.
SELECTING THE TEST TYPE:
Having selected a system, the first available test type will be displayed (i.e. PCM DATA?, PCM CLEAR CODES?). While selecting a specific test type, any of the following actions may be taken:
  1. Depressing the "HI" button on the CCC will select the displayed test type. At this point the first of several specific tests will appear.
  2. Depressing the "LO" button on the CCC will display the next available test type for the selected system. This allows the display to be stepped through all available test type choices. This list of test types can be repeated following the display of the last test type.
  3. Depressing the "OFF" button on the CCC will stop the test type selection process and return the display to the next available system selection.
CLEAR CODES
Selection of "CLEAR CODES?" test will result in the message "CODES CLEARED" being displayed along with the selected systems name. This message will appear for 3 seconds and then return to the next available test type.
EXITING DIAGNOSTIC MODE:
To get out of the diagnostic mode anytime during the test, depress the "AUTO" or "DEFOG" button, or turn the ignition switch "OFF." Trouble codes are not erased if this is done prior to selecting "CODES CLEARED."
ECC Trouble Code Descriptions:
  • DTC A010 - Outside Temperature Sensor Circuit
  • DTC A011 - High Side Temperature Sensor Circuit
  • DTC A012 - Low Side Temperature Sensor Circuit
  • DTC A013 - In-Car Temperature Sensor Circuit
  • DTC A015 - Sunload Sensor Circuit
  • DTC A037 - Loss of IPC Data
  • DTC A040 - Air Mix Valve (Door) Circuit Problem
  • DTC A047 - Low Refrigerant Charge
  • DTC A048 - Low Refrigerant Pressure
  • DTC A050 - HVAC - Coolant Temperature Too High
Jan 28, 2010 | 1994 Cadillac DeVille
I need to re-program the day on avaya 18d telephone.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
enter in "#101"
the display should say system date and the current programmed date.
enter the new datein MMDDYY format
press feature "00" to logout
Older partner systems also had an additional place to program the system day
enter in "#102"
the display should say system day.
the display should have the current programmed day of the week
press the digit for the day of the week (1=sunday 2=monday etc.)
Sep 29, 2009 | Avaya Partner 18 Eurostyle 18D telephone
How can I know that the Battery Maintenance System is charging.Does the battery voltage displays on the screen??
Hai dud,
A battery maintenance system for charging, analyzing, discharging and conditioning of a NiCad battery. The system displays voltage and capacity to determine whether or not a NiCad battery has enough capacity to power equipment for an optimal time period. The system charges the battery using a negative delta voltage method of detecting full charge, while also displaying instantaneous battery voltage. The system also analyzes the battery in a charge, discharge and recharge mode of operation, and during the charge mode the instantaneous voltage is displayed. The discharge mode discharges the battery to one volt per cell while displaying voltage and accumulative capacity alternately. The system also conditions batteries by cycling a battery through three cycles of charging, discharging and a subsequent recharge cycle.
Hope it Helped You!
Aug 03, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Display problem
may be ur display & graphics driver not installed properly , first u uninstall the driver from ur system and restart the system after restarting the system reinstall these drivers properly after one driver installing if it ask for restart then restart the system , after restarting the system check. I think ur problem will solved
Jun 02, 2009 | Dell Latitude D800 Notebook
Hear power on, black screen. wont do anything.
- try to connect you machine to an external monitor
- if the display appears on your external monitor the problem would be the LCD screen of your laptop (need to replace it)
- if there is no display on both laptop and external monitor i suspected it's the motherboard faulty
- send your laptop to service center to replace it (if it is underr warranty it's free
May 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
MLS-12d phone system
Your system is actually called Partner.
Compatible phones will consist of MLS12, MLS12D(display),Mls18, 18D(caller id display), 6D(display), 34, 34D(display) No other phone will work on this system
To program phone numbers
Press Feature 00, press/select a buton to program, input speed dial number. Press Feature 00 again.
Mar 22, 2009 | AT&T Lucent MLS-12D Phone
How do I change the date on the Lucent D18 Phone?
Some advice from the Avaya support web site: How do I program System Time? To program the System Time on Basic Partner Release 4.1:
This System Programming procedure sets the time that appears on system display phones.
Enter the time in 24-hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2359 (11:59 p.m.). Since each time must have four digits, use leading zeros when necessary. For example, to set the time to 9:00 a.m., enter 0900. For 4:45 p.m., enter 1645.
The time appears on system display phones as a.m. or p.m. (not in 24-hour notation).
To change the System Time using a display phone at extension 10 or 11:
Press Feature 00. Press System Program (Left Intercom button). Press System Program (Left Intercom button). Press # 103. Enter the time in 24-hour notation. For example, to set the time to 2:15p.m., press 1415. A display similar to the following appears:
System Time Data 1415 Note: The time will appear on system display phones as 2:15p.
Select another procedure or press Feature 00 to exit programming mode.
Mar 09, 2009 | Lucent PARTNER18 Corded Phone
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Toshiba Satellite A135-S2276 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
